Type
17 inches
TFT LCD
43.2 cm
Viewable Image Size
17–inch diagonal
43.2 cm
Tilt
-5 to 25°
Maximum Weight (Unpacked)
9.9 lbs.
4.5 kg
Dimensions (include base)
Height
Depth
Width
15.2 inches
7.56 inches
14.9 inches
38.6 cm
19.2 cm
37.7 cm
Maximum Graphic Resolution
1280 × 1024 (75 Hz) analog input
Optimum Graphic Resolution
1280 x 1024 (60Hz) analog input
Text Mode
720 × 400
Dot Pitch
0.264 (H) × 0.264 (W) mm
Horizontal Frequency
24 to 83 kHz
Vertical Refresh Rate
50 to 77 Hz
Environmental Requirements Temperature
Operating Temperature
Storage Temperature
41 to 95° F
-29 to 140° F
5 to 35° C
-20 to +60° C
Relative Humidity
20 to 80%
Power Source
90 — 265 VAC, 45/63 Hz
Altitude:
Operating
Storage
0 to 12,000 feet
0 to 40,000 feet
0 to 3657.6 m
0 to 12192 m
Power Consumption (maximum)
<45 watts
Input Terminal
One VGA connector with cable included
- ${title}
- ${title}
- ${title}
- ${title}
17-inch LCD Monitor Specifications - L1710 Model
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
