    Looking for Site Help?
HP Designjet T1100 and T1120 MFP Series Products - Set a Scale Factor
Set a scale factor
  1. After making input setting, if in the Copy tab, press the Scale button. If in the Scan tab, press Resize -> Scale. These actions will display the list of standard or customized scaling factors predefined in your system.
  2. Select the Scale value that fits your intentions. A scale factor of 100% makes a 1:1 duplicate. Below 100% reduces the image and above 100% magnifies it.
  3. If you need to define a new scale factor: select the Tool button to open the Scale setup dialog. Here you can manually set a scale factor with the Value button.
  4. To save a new scale factor by adding it to the list of predefined scale factors - Press the New button to give the new scale factor a name and the Value button to enter its value. Press the Save button to add it to the list.
Make a fast miniature version of your big copy by setting the Scale factor to 25%.
When you select Auto for the Input Size and a specific Output Size, the Scale value will be set to Auto by the scanner software until the first preview after which the calculated Scale value percentage will be displayed.
Country: Flag Thailand
