HP LaserJet M3027/M3035 MFP Series Product - Manage supplies
Using, storing, and monitoring the print cartridge can help ensure high-quality output.
Supplies life
The average cartridge yield is 6,500 pages (for the Q7551A cartridge) or 13,000 pages (for the Q7551X cartridge), in accordance with ISO/IEC 19752. Actual cartridge yield depends on specific use.
EconoMode is a feature that allows the device to use less toner per page. Selecting this option may extend the life of the toner supply and may reduce cost per page. However, it will also reduce print quality. The printed image is lighter, but it is adequate for printing drafts or proofs. HP does not recommend full-time use of EconoMode. If EconoMode is used full-time, it is possible that the toner supply will outlast the mechanical parts in the print cartridge. If print quality begins to degrade under these circumstances, you will need to install a new print cartridge, even if there may be toner supply remaining in the cartridge.
Approximate print-cartridge replacement intervals
Print cartridge
Page count
Approximate time period1
Black (Q7551A)
6,500 pages1
3 months
Black (Q7551X)
13,000 pages
6 months
1Approximate life is based on 2,000 pages per month.
Manage the print cartridge
Print-cartridge storage
Do not remove the print cartridge from its package until you are ready to use it.
To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.
Use genuine HP print cartridges
When you use a genuine new HP print cartridge, you can obtain the following supplies information:
  • Percentage of supplies remaining
  • Estimated number of pages remaining
  • Number of pages printed
HP policy on non-HP print cartridges
Hewlett-Packard Company cannot recommend the use of non-HP print cartridges, either new or remanufactured. Because they are not HP products, HP cannot influence their design or control their quality.
Any damage caused by a non-HP print cartridge is not covered under the HP warranty and service agreements.
To install a new HP print cartridge, see Change the print cartridge. To recycle the used cartridge, follow the instructions included with the new cartridge.
Print-cartridge authentication
The device automatically authenticates the print cartridge when it is inserted into the device. During authentication, the device notifies you whether a cartridge is a genuine HP print cartridge.
HP fraud hotline and Web site
Call the HP fraud hotline (1-877-219-3183, toll-free in North America) or go to www.hp.com/go/anticounterfeit when you install an HP print cartridge and the control-panel message says the cartridge is non-HP. HP will help determine if the cartridge is genuine and take steps to resolve the problem.
Your print cartridge might not be a genuine HP print cartridge if you notice the following:
  • You are experiencing a high number of problems with the print cartridge.
  • The cartridge does not look like it usually does (for example, the orange pull tab is missing, or the packaging differs from HP packaging).
Country: Flag Thailand
