HP LaserJet M3027/M3035 MFP Series Product - Use features in the Macintosh printer driver
When you print from a software program, many of the printer features are available from the printer driver. For complete information about the features that are available in the printer driver, see the printer-driver Help. The following features are described in this section:
Settings in the printer driver and software program generally override control-panel settings. Software-program settings generally override printer-driver settings.
Create and use presets
Use presets to save the current printer driver settings for reuse.
Create a preset
  1. Open the printer driver (see Open the printer drivers).
  2. Select the print settings.
  3. In the Presets box, click Save As..., and type a name for the preset.
  4. Click OK.
Use presets
  2. In the Presets menu, select the preset that you want to use.
To use printer-driver default settings, select the Standard preset.
Print a cover page
You can print a separate cover page for your document that includes a message (such as "Confidential").
  2. On the Cover Page or Paper/Quality pop-up menu, select whether to print the cover page Before Document or After Document.
  3. In the Cover Page Type pop-up menu, select the message that you want to print on the cover page.
    To print a blank cover page, select Standard as the Cover Page Type.
Print multiple pages on one sheet of paper
You can print more than one page on a single sheet of paper. This feature provides a cost-effective way to print draft pages.
  2. Click the Layout pop-up menu.
  3. Next to Pages per Sheet, select the number of pages that you want to print on each sheet (1, 2, 4, 6, 9, or 16).
  4. Next to Layout Direction, select the order and placement of the pages on the sheet.
  5. Next to Borders, select the type of border to print around each page on the sheet.
Printing on both sides of the paper
When a duplexer is available, you can automatically print on both sides of a page. Otherwise, you can manually print on both sides of a page by feeding the paper through the printer a second time.
To avoid jams, do not load paper that is heavier than 105 g/m2 (28-lb bond).
Use automatic duplex printing
  1. Insert enough paper into one of the trays to accommodate the print job. If you are loading special paper such as letterhead, load it in one of the following ways:
    • For tray 1, load the letterhead paper face-up with the bottom edge feeding into the printer first.
    • For all other trays, load the letterhead paper face-down with the top edge at the back of the tray.
  2. Open the printer driver (see Open the printer drivers).
  3. Open the Layout pop-up menu.
  4. Next to Two Sided Printing, select either Long-Edge Binding or Short-Edge Binding.
  5. Click Print.
Print on both sides manually
  3. On the Finishing pop-up menu, select the Manual Duplex option.
    If the Manual Duplex option is not enabled, select Manually Print on 2nd Side.
  4. Click Print. Follow the instructions in the pop-up window that appears on the computer screen before replacing the output stack in tray 1 for printing the second half.
  5. Go to the printer, and remove any blank paper that is in tray 1.
  6. Insert the printed stack face-up with the bottom edge feeding into the printer first in tray 1. You must print the second side from tray 1.
  7. If prompted, press the appropriate control-panel button to continue.
Country: Flag Thailand
