Printer Specifications for the HP Officejet Pro L7480 All-in-One Printer
Figure : HP Officejet Pro L7480 All-in-One
Product models
Printer Number
Product Number
HP OfficeJet Pro L7480 All-in-One
CB060A
CB061A
System Requirements
Windows
Component
Minimum
Recommended
Windows 2000, Windows XP, Windows XP 64-bit (Professional and Home Editions), Windows Vista
Processor
Windows 2000: Intel Pentium II or Celeron processor
Windows XP 64-bit edition: Intel Pentium II or Celeron processor
Windows 2000: Intel Pentium III or higher processor
Windows XP 64-bit edition: Intel Pentium III or higher processor
RAM
128 MB
256 MB
Free disk space
280 MB free hard disk space for software installation
Full-color scanning requires additional 50 MB hard disk space
400 MB free hard disk space for software installation
Video display
SVGA 800 x 600 monitor with 16-bit color or higher
Connectivity
USB 2.0-compliant high speed
Browser
Internet Explorer 6.0
Internet Explorer 6.0 or later
Macintosh
Component
Minimum
Recommended
Mac OS X 10.3.9 or higher
Processor
333 MHz
333 MHz
RAM
128 MB
256 MB
Free disk space
100 MB
200 MB
Video display
800 x 600, 16-bit or higher
Connectivity
USB 2.0 full speed, front and back ports
Physical dimensions
Dimension
Value
Height
273.05 mm (10.75 inches)
Width
496 mm (19.5 inches)
Depth
403.2 mm (15.9 inches)
9.7 kg (21.4 lb)
Cartridges
Paper-handling specifications
Paper tray capacity
Tray
Type
Maximum Media Weight Range
Capacity
Tray 1 1
Paper
60 to 105 g/m2 (16 to 28 lb bond)
Up to 250 sheets of plain paper (25 mm or 1 inch stacked)
Transparencies
60 to 200 g/m2 (16 to 110 lb index)
Up to 70 sheets (17 mm or 0.67 inch stacked)
Photo paper
280 g/m2 (75 lb bond)
Up to 100 sheets (17 mm or 0.67 inch stacked)
Labels
Envelopes
75 to 90 g/m2 (20 to 24 lb bond envelope)
Up to 30 sheets (17 mm or 0.67 inch stacked)
Cards
Up to 200 g/m2 (110 lb index)
Up to 80 cards
Tray 2 1
Plain media
Up to 350 sheets of plain paper (35 mm or 1.38 inch stacked)
Output tray 1 2
All supported media
Up to 150 sheets of plain paper (text printing)
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you use. HP recommends emptying the output tray frequently.
Paper types and sizes
Type
Size
Paper
U.S. Letter: 216 x 280 mm (8.5 x 11 inches)
U.S. Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm (8.27 x 11.7 inches)
A5: 148 x 210 mm (5.83 x 11.7 inches)
A6: 105 x 148 mm (4.13 x 5.83 inches)
B4: 250 x 353 mm (9.84 x 13.9 inches)
B5: 176 x 250 mm (6.93 x 9.84 inches)
B6: 125 x 176 mm (4.92 x 6.93 inches)
C5: 162 x 229 mm (6.38 x 9.01 inches)
C6: 114 x 162 mm (4.49 x 6.38 inches)
JIS B5: 182 x 257 mm (7.2 x 10.1 inches)
U.S. Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches)
Custom: 76 x 127 to 216 x 356 mm
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. 9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
U.S. Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium Photo Paper
102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards
A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Hagaki: 100 x 148 mm (3.94 x 5.83 inches)
Labels
A4: 210 x 297 mm
Custom
102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14 inches)
Print margin specifications
Media
Top (TM)
Left (LM)
Right (RM)
Bottom (BM)
U.S. Letter, U.S. Legal, A4, U.S. Statement, 8.5 x 13 inch, customized media, photo media
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
U.S. Executive, B5, A5, cards
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
Envelopes
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
16 mm (0.63 inch)
16 mm (0.63 inch)
Printing specifications
Component
Specification
Print method
Drop-on-demand thermal inkjet printing
Device languages
HP PCL 3 enhanced
Print speed (varies by model)
Up to 20 pages per minute (ppm) black after first page. Up to 13 ppm color after first page. For more details, go to the Inkjet Printer page on the HP Web site.
Print speeds vary according to the complexity of the document.
Print resolution
Up to 1200 dpi with pigmented black ink. Up to 4800 by 1200 dpi optimized on HP Premium Plus photo papers with 1200 by 1200 input dpi
Duty cycle
Up to 7500 pages per month
Mode
Type
Speed (ppm)
Draft mode
Black text
*up to 37 after first page
Mixed text with color graphics
*up to 32 after first page
Normal
Black text
*up to 16 after first page
Best
Black text
*up to 5 after first page
Laser quality speed
Black text
*up to 12 after first page
*up to 10 after first page
*: For more details, go to the Inkjet Printer page on the HP Web site.
Copying specifications
  • Digital image processing
  • Up to 99 copies from original (varies by model)
  • Digital zoom: from 25% to 400% (varies by model)
  • Fit to page, pre-scan
  • Copy speeds vary according to the complexity of the document
Mode
Type
Speed (ppm).
Scan resolution (dpi) (maximum at 400% scaling)
Best
Black
up to .85
up to 600 x 1200
Color
up to .75
up to 600 x 1200
Normal
Black
up to 4.1
up to 300 x 300
Color
up to 2.8
up to 300 x 300
Fast
Black
up to 20
up to 300 x 300
Color
up to 13
up to 300 x 300
Scanning specifications
  • Image editor included
  • Integrated OCR software automatically converts scanned text to editable text
  • Twain compliant interface
  • Scan speeds vary according to the complexity of the document
  • Resolution: 1200 x 2400 dpi optical, up to 19,200 dpi enhanced
  • Color: 16-bit per RGB; 48 bit total
  • Maximum scan size from the glass: 216 x 297 mm (8.5 x 11.7 inches)
Power consumption
  • Power consumption: 40 W (average printing)
  • Idle state power consumption: 5.593 W
  • Input voltage: 100 to 240 VAC (± 10 %), 50/60 Hz (± 3Hz)
  • Output voltage: 32 Vdc, 2500 mA
Environmental specifications
Operating conditions
  • Recommended operating temperature range: 15° to 35° C (59° to 95° F)
  • Allowable operating temperature range: 5° to 40° C (41° to 104° F)
  • Humidity: 15 to 80% non-condensing
  • Non-operating (storage) temperature range: minus 40 to 60 degrees Celsius (minus 40 to 140 degrees Fahrenheit)
  • In the presence of high electromagnetic fields it is possible that the output from the HP Officejet may be slightly distorted
    HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Regulatory specifications
This equipment has been tested and found to comply with the limits for a Class B digital device, according to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it might cause harmful interference to radio communications. However, there is no guarantee that interference does not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try correcting the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult a dealer or an experienced radio/TV technician.
Any changes or modifications to the product that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
