    Fix HP Printer issue on macOS
Document ID: c01131067
Version: 1
Greater Than 4 GB Of Memory Is Not Accessible In Microsoft Windows XP Professional
Release date : 07-Aug-2007
Last updated : 04-Nov-2004
DESCRIPTION
Currently workstations listed in the SCOPE section of this document cannot access memory in excess of 4 GB.
SCOPE
  • HP Workstation xw4200, xw6200 or xw8200 running Microsoft Windows XP Professional.
RESOLUTION
  • HP has written a white paper discussing memory allocation in Microsoft Windows XP Professional. To access more than 4 GB of memory the Windows client OS (Windows XP Professional) needs to be upgraded to the future 64-bit version of Windows. In addition, while the current 32-bit client versions of Windows for x86-based computers can access 4 GB of virtual memory with today's large disk drives, less than 4 GB of physical RAM can be accessed. The complete white paper titled " What Happens when 3 GB or more RAM is installed with Windows?" is available at http://h20331.www2.hp.com/Hpsub/downloads/3_plus_GB_RAM_w-Windows_08Ap07.pdf
RECEIVE PROACTIVE UPDATES: Receive support alerts (such as the document you are reading), as well as updates on drivers, software, firmware, and customer replaceable components, pro-actively via e-mail through HP Subscriber's Choice for your specific HP Workstation. Click here to sign up for Subscriber's Choice.
REVISION HISTORY : Supersedes Customer Advisory: WO041026_CW01
Hardware platforms affected : HP xw4200 Workstation, HP xw6200 Workstation, HP xw8200 Workstation
Operating systems affected : Microsoft Windows XP
Support Communication Cross Reference ID : IA01131067
