HP Compaq 2210b Notebook PC Specifications
Product description
Starting at only 1.65 kg and 28.2 mm thin, this solution is packed with HP innovation to offer you all the functionality of an ultra-light notebook plus the added flexibility of an ultra-slim tablet PC.
Product features
Processor and Memory
Processor Type
GT573PA / GT562PA / GT571PA / GT574PA: Intel Centrino Duo processor technology
• Intel Core2 Duo Processor T7100
• 1.80 GHz, 2 MB L2 cache, 800 MHz FSB
• Intel Wireless LAN 802.11a/b/g, Bluetooth 2.0+
GT572PA / GT596PA: Intel Centrino Duo processor technology
• Intel Core2 Duo Processor T7300
• 2.0 GHz, 4 MB L2 cache, 800 MHz FSB
GP180PA: Intel Core2 Duo Processor T7100
Mobile Intel GM965
Standard Memory
  • GT573PA / GT562PA / GP180PA / GT574PA: 1 x 1024 MB DDR2
  • GT571PA: 1 x 512 MB DDR2
  • GT596PA: 2 x 1024 MB DDR2
  • GT572PA: 2 x 512 MB DDR2
Memory Upgrade
Upgradeable to 4096 MB maximum
Memory Slots
2 SODIMM slots supporting dual channel memory
System Features
Internal Hard Disk Drive
  • GT571PA / GP180PA / GT596PA: 120 GB
  • GT573PA / GT562PA / GT572PA / GT574PA: 160 GB
Hard Disk Drive Speed
5400 rpm
Optical Drives
DVD+/-RW SuperMulti with Double Layer
Multi-bay Devices
Optional external Multibay II devices
Portability
Starting at 1.68 kg
Dimensions (W x D x H)
30.6cm(W) x 22.8cm(D) x 2.8cm (at front) (H)
Display Size
12.1 inches diagonal
Connectivity
Wireless Technologies
  • GT573PA / GT562PA / GT571PA / GT572PA / GT574PA / GT596PA: Intel Wireless LAN 802.11a/b/g, Bluetooth 2.0+
  • GP180PA: Wireless LAN 802.11b/g, Bluetooth 2.0+
Network Interface
Integrated Broadcom NetLink Gigabit Ethernet Controller (10/100/1000 NIC)
Expandability
Expansion Slots
1 ExpressCard/54 slot supports form factor of ExpressCard/54 and ExpressCard/34, Media Card Reader supports SD (Secure Digital), MMC (MultiMedia Card) cards
External I/O Ports
3 USB 2.0 ports, VGA, stereo microphone in, stereo headphone/line out, RJ-11/MODEM, RJ-45/ethernet, S-video TV out, Smart AC adapter, Power connector, Internal microphone, secure digital
Graphic/Audio
Graphic Subsystem Video Card Memory
Up to 384 MB shared system memory
Graphic Subsystem Name
Mobile Intel Graphics Media Accelerator X3100
Other Information
Keyboard
Full-sized keyboard
Pointing Device
Touchpad with scroll zone
Power Features
  • GT573PA / GT562PA / GT571PA / GT572PA / GP180PA / GT574PA: HP 4-cell (37 WHr) Lithium-Ion battery
  • GT596PA: HP 8-cell (73 WHr) Lithium-Ion battery
Power Requirements
HP 65W Smart AC Adapter
Docking Solution
HP Smart AC Adapters, HP 9.5 mm External MultiBay II Cradle (all sold separately)
Security Management
HP ProtectTools, HP Fingerprint Sensor, Kensington Lock Slot, HP Privacy Filter (optional, available only at point of purchase), Configuration Control Hardware, Memory Change Alert, Ownership Tag, Setup Password, Power-On Password, HP Disk Sanitizer, HP 3D DriveGuard
Computer specifications
Metric
U.S.
Dimensions
Length
30.6 cm
12.01 in
Width
22.5 cm
8.86 in
Height (front to rear)
2.8 to 3.3 cm
1.10 to 1.29 in
Equipped with 8-cell battery and optical drive
2.12 kg
4.67 lbs
Equipped with 4-cell battery and optical drive
1.92 kg
4.23 lbs
Input power
Operating voltage
19.0 V dc @ 4.74 A – 65 W
Operating current
4.74 A
Temperature
Operating (not writing to optical disc)
0°C to 35°C
32°F to 95°F
Operating (writing to optical disc)
5°C to 35°C
41°F to 95°F
Nonoperating
-20°C to 60°C
-4°F to 140°F
Relative humidity
Operating
10% to 90%
Nonoperating
5% to 95%
Maximum altitude (unpressurized)
Operating (14.7 to 10.1 psia)
-15 m to 3,048 m
50 ft to 10,000 ft
Nonoperating (14.7 to 4.4 psia)
-15 m to 12,192 m
-50 ft to 40,000 ft
Shock
Operating
125 g, 2 ms, half-sine
Nonoperating
200 g, 2 ms, half-sine
Random vibration
Operating
0.75 g zero-to-peak, 10 Hz to 500 Hz, 0.25 oct/min sweep rate
Nonoperating
1.50 g zero-to-peak, 10 Hz to 500 Hz, 0.5 oct/min sweep rate
Applicable product safety standards specify thermal limits for plastic surfaces. The computer operates well within this range of temperatures.
12.1-inch, WXGA display specifications
Metric
U.S.
Dimensions
Height
16.9 cm
6.7 in
Width
26.2 cm
10.3 in
Diagonal
30.8 cm
12.1 in
Number of colors
Up to 16.8 million
Contrast ratio
250:1 (typical)
Brightness
180 nits (typical)
Pixel resolution
Pitch
0.279 × 0.279 mm
Format
1280 × 800
Configuration
RGB vertical stripe
Backlight
Edge lit
Character display
80 × 25
Total power consumption
4.0 W
Viewing angle
+/-40 horizontal, +120/–40° vertical (typical)
Hard drive specifications
200-GB*
160-GB*
120-GB*
80-GB*
Dimensions
Height
9.5 mm
9.5 mm
9.5 mm
9.5 mm
Width
70 mm
70 mm
70 mm
70 mm
101 g
101 g
101 g
101 g
Interface type
SATA
SATA
SATA
SATA
Transfer rate
100 MB/sec
100 MB/sec
100 MB/sec
100 MB/sec
Security
ATA security
ATA security
ATA security
ATA security
Seek times (typical read, including setting)
Single track
3 ms
3 ms
3 ms
3 ms
Average
13 ms
13 ms
13 ms
13 ms
Maximum
24 ms
24 ms
24 ms
24 ms
Logical blocks
390,700,850
312,560,640
234,420,480
156,280,320
Disc rotational speed
4200 rpm
5400 rpm
5400 rpm
5400 rpm
Operating temperature
5°C to 55°C (41°F to 131°F)
*1 GB = 1 billion bytes when referring to hard drive storage capacity. Actual accessible capacity is less. Actual drive specifications may differ slightly.
Certain restrictions and exclusions apply. Contact technical support for details.
DVD/CD-RW Combo Drive specifications
Applicable disc
Read:
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Write:
CD-R and CD-RW
Center hole diameter
1.5 cm (0.59 in)
Disc diameter
Standard disc
12 cm (4.72 in)
Mini disc
8 cm (3.15 in)
Disc thickness
1.2 mm (0.047 in)
Track pitch
0.74 µm
Access time
CD
DVD
Random
< 110 ms
< 130 ms
Full stroke
< 210 ms
< 225 ms
Audio output level
Line-out, 0.7 Vrms
Cache buffer
2 MB
Data transfer rate
24X CD-ROM
3,600 KB/sec
8X DVD
3,600 KB/sec
24X CD-R
3,600 KB/sec
24X CD-RW
3,600 KB/sec
Transfer mode
Multiword DMA mode 2
Startup time
< 15 seconds
Stop time
< 6 seconds
DVD-ROM Drive
Applicable disc
DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18, CD-ROM (Mode 1 and 2), CD Digital Audio, CD-XA ready (Mode 2, Form 1 and Form 2), CD-I (Mode 2, Form 1 and Form 2), CD-R, CD-RW, Photo CD (single and multisession), CD-Bridge
1.5 cm (0.59 in)
Disc diameter
Standard disc
Mini disc
12 cm (4.72 in)
8 cm (3.15 in)
Disc thickness
1.2 mm (0.047 in)
Track pitch
0.74 µm
Access time
CD
DVD
Random
< 100 ms
< 125 ms
Full stroke
< 175 ms
< 225 ms
Audio output level
Line-out, 0.7 Vrms
Cache buffer
512 KB
Data transfer rate
CD-R (24X)
3600 KB/s (150 KB/s at 1X CD rate)
CD-RW (10X)
1500 KB/s (150 KB/s at 1X CD rate)
CD-ROM (24X)
DVD (8X)
10,800 KB/s (1,352 KB/s at 1X DVD rate)
16.6 MB/s
Startup time
< 10 seconds
Stop time
< 3 seconds
System DMA specifications
Hardware DMA
System function
DMA0
Not applicable
DMA1*
Not applicable
DMA2*
Not applicable
DMA3
Not applicable
DMA4
Direct memory access controller
DMA5*
Available for PC Card
DMA6
Not assigned
DMA7
Not assigned
*PC Card controller can use DMA 1, 2, or 5.
System interrupt specifications
Hardware IRQ
System function
IRQ0
System timer
IRQ1
Standard 101-/102-Key or Microsoft® Natural Keyboard
IRQ2
Cascaded
IRQ3
Intel 82801DB/DBM USB2 Enhanced Host Controller—24CD
IRQ4
COM1
IRQ5*
Conexant AC—Link Audio Intel 82801DB/DBM SMBus Controller—24C3 Data Fax Modem with SmartCP
IRQ6
Diskette drive
IRQ7*
Parallel port
IRQ8
System CMOS/real-time clock
IRQ9*
Microsoft ACPI-compliant system
IRQ10*
Intel USB UHCI controller—24C2
Intel 82852/82855 GM/GME Graphic Controller
Realtek RTL8139 Family PCI Fast Ethernet Controller
IRQ11
Intel USB EHCI controller—24CD
Intel USB UHCI controller—24C4
Intel USB UHCI controller—24C7
Intel Pro/Wireless 2200BG
TI OHCI 1394 host controller
TI PCI1410 CardBus controller
IRQ12
Synaptics PS/2 TouchPad
IRQ13
Numeric data processor
IRQ14
Primary IDE channel
IRQ15
Secondary IDE channel
*Default configuration; audio possible configurations are IRQ5, IRQ7, IRQ9, IRQ10, or none.
PC Cards may assert IRQ3, IRQ4, IRQ5, IRQ7, IRQ9, IRQ10, IRQ11, or IRQ15. Either the infrared or the serial port may assert IRQ3 or IRQ4.
System I/O address specifications
I/O address (hex)
System function (shipping configuration)
000 - 00F
DMA controller no. 1
010 - 01F
Unused
020 - 021
Interrupt controller no. 1
022 - 024
Opti chipset configuration registers
025 - 03F
Unused
02E - 02F
87334 “Super I/O” configuration for CPU
040 - 05F
Counter/timer registers
044 - 05F
Unused
060
Keyboard controller
061
Port B
062 - 063
Unused
064
Keyboard controller
065 - 06F
Unused
070 - 071
NMI enable/RTC
072 - 07F
Unused
080 - 08F
DMA page registers
090 - 091
Unused
092
Port A
093 - 09F
Unused
0A0 - 0A1
Interrupt controller no. 2
I/O Address (hex)
System Function (shipping configuration)
0A2 - 0BF
Unused
0C0 - 0DF
DMA controller no. 2
0E0 - 0EF
Unused
0F0 - 0F1
Coprocessor busy clear/reset
0F2 - 0FF
Unused
100 - 16F
Unused
170 - 177
Secondary fixed disk controller
178 - 1EF
Unused
1F0 - 1F7
Primary fixed disk controller
1F8 - 200
Unused
201
JoyStick (decoded in ESS1688)
202 - 21F
Unused
220 - 22F
Entertainment audio
230 - 26D
Unused
26E - 26
Unused
278 - 27F
Unused
280 - 2AB
Unused
2A0 - 2A7
Unused
2A8 - 2E7
Unused
2E8 - 2EF
Reserved serial port
2F0 - 2F7
Unused
2F8 - 2FF
Infrared port
300 - 31F
Unused
320 - 36F
Unused
370 - 377
Secondary diskette drive controller
378 - 37F
Parallel port (LPT1/default)
380 - 387
Unused
388 - 38B
FM synthesizer—OPL3
38C - 3AF
Unused
3B0 - 3BB
VGA
3BC - 3BF
Reserved (parallel port/no EPP support)
3C0 - 3DF
VGA
3E0 - 3E1
PC Card controller in CPU
3E2 - 3E3
Unused
3E8 - 3EF
Internal modem
3F0 - 3F7
“A” diskette controller
3F8 - 3FF
Serial port (COM1/default)
CF8 - CFB
PCI configuration index register (PCIDIVO-1)
CFC - CFF
PCI configuration data register (PCIDIVO-1)
System memory map specifications
Size
Memory address
System function
640 KB
00000000-0009FFFF
Base memory
128 KB
000A0000-000BFFFF
Video memory
48 KB
000C0000-000CBFFF
Video BIOS
160 KB
000C8000-000E7FFF
Unused
64 KB
000E8000-000FFFFF
System BIOS
15 MB
00100000-00FFFFFF
Extended memory
58 MB
04800000-07FFFFFF
Super extended memory
58 MB
04800000-07FFFFFF
Unused
2 MB
08000000-080FFFFF
Video memory (direct access)
4 GB
08200000-FFFEFFFF
Unused
64 KB
FFFF0000-FFFFFFFF
System BIOS
Software/OS
Feature
Specification
Operating System Installed
  • GT573PA / GT562PA / GT571PA / GT572PA / GT596PA: Genuine Windows Vista Business 32-bit
  • GP180PA / GT574PA: Genuine Windows XP Professional
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
