HP Compaq dc5750 Microtower PC Product Specifications
Product Description
A new chassis design with optimized thermals and acoustics to help maximize PC performance and minimize disruption, offering increased power and expandability in a Microtower configuration.
Product Features
Feature
Processor, operating system and memory
Operating system installed
Genuine Windows XP Home SP2,
FreeDOS
Processor
AMD Sempron Processor 3400+ / 3600+ with HT Technology(1.8 to 2 GHz, 256 KB L2 cache, 1600 MHz FSB), AMD Athlon 64 Processor 3500+ / 3800+ with HT Technology (2.2 to 2.4 GHz, 512 KB L2 cache, 2000 MHz FSB) or AMD Athlon 64 X2 Dual Core Processors 3800+ / 4200+ / 4600+ with HT Technology (2.0 to 2.4 GHz, 2 x 512 KB L2 cache, 2000 MHz FSB)
Cache
256 KB, 512 KB or 2 x 512 KB L2 cache
System bus
1600 or 2000 MHz Front Side Bus
ATI Radeon Xpress 1150 Professional
Memory type
From 256 MB to 4 GB DDR2-Synch DRAM PC2-5300 (dual channel configurations)
Memory slots
4 DIMM
Memory upgrade
Expandable to 4 GB through four industry-standard DIMM slots
Maximum memory
Internal drives
Hard disk drive
80 to 250 GB Serial ATA 3.0 GB/s SMART III hard drive
Hard disk speed
7200 rpm
External drive bays
2 external 5.25 inch and 1 external 3.5 inch
Internal drive bays
2 internal 3.5 inch
Optical drives
SATA 48X/32X Combo CD-RW/DVD-ROM Drive, SATA 16X/48X DVD-ROM Drive, SATA 16X DVD+/-RW LightScribe Drive (Double Layer/Dual Format)
Flexible disk drive
Optional 1.44-MB Diskette Drive
Disk subsystem controller
SMART III Serial ATA 3.0 GB/s
System features
Chassis
Microtower
Graphic card 01
Integrated ATI Radeon Xpress 1150 Graphics
Graphic subsystem video card features 01
RAMDAC integrated (400-MHz); Controller Clock Speed: 400 MHz; Overlay Planes: Back end overlay supporting Motion Adaptive De-Interlacing; Max Color Depth: 32-bits/pixel; Multi-display Support: Up to 2 displays can be supported via the motherboard's VGA and DVI-D connectors.
Graphic subsystem video card memory 01
HYPERMEMORY technology offers optional dedicated Local Frame Buffer configuration for a 32-bit or 64-bit interface and up to 128MB of memory. UMA mode operation uses from 32MB up to 256MB of shared system memory
Supports resolutions up to 2045x1536 @ 32bpp
Expansion slot
2 full-height PCI, 1 full-height PCI Express x1, 1 full-height PCI Express x16
Internal audio
Integrated High Definition audio with Realtek 2 channel ALC260 codec
Fax/modem
Optional Agere 56K PCI Modem
Integrated Broadcom NetXtreme Gigabit Ethernet for HP
Network cards
Broadcom 5755 Gigabit Ethernet integrated on system board
Available LAN drivers
Microsoft 2000, Microsoft XP
I/O port
Rear: 6 USB 2.0, 1 VGA port, 1 DVI-D, 1 optional serial port, 1 parallel, 2 PS/2, 1 RJ-45, 1 VGA, audio in/out; Front: 2 USB 2.0, headphone and microphone
Pre-installed software
HP Client Management Solutions, HP Backup and Recovery Manager, Computer Setup Utility, Symantec AntiVirus with 60 day Live Update, Microsoft Internet Explorer, PDF Complete, Altiris Local Recovery, HP Open View Radia Management Agent; Optional preloaded software, only for certain configurations: Microsoft Office 2003 Basic, Microsoft Office 2003 Small Business
Keyboard
HP PS/2 or USB Standard Keyboard, USB BG1650 2004 standard keyboard, USB Smartcard Keyboard
Pointing device
PS/2 2-Button scroll mouse, PS/2 2-Button optical scroll mouse or 2-button USB optical scroll mouse
Physical security features
Kensington Cable Lock, Hood Cover Security Loop supported, Optional Keyed Security Lock, embedded security (TPM 1.2) (except for Russia) module
Dimensions, metric
17.65 x 42.80 x 37.72 cm
Weight, metric
10.66 kg
Power consumption
300 watts maximum
Power requirements
Input voltage 90 – 264 VAC, ATX Power Supply – passive PFC (115v/230v line)
Protected by HP Services, including a 3-3-3 standard warranty. Terms and conditions vary by country. Certain restrictions and exclusions apply
Software/OS
Feature
Altiris Deployment Solution Agent, HP Client Manager Software, HP OpenView, HP Backup and Recovery Manager
Certain Windows Vista product features require advanced or additional hardware. See
http://www.microsoft.com/windowsvista/getready/hardwarereqs.mspx and
http://www.microsoft.com/windowsvista/getready/capable.mspx for details. Windows Vista Upgrade Advisor can help you determine which features of Windows Vista will run on your computer. To download the tool, visit
http://www.windowsvista.com/upgradeadvisor.
** HP's WEEE registration number is WEE/EJ0076US This means that HP is a registered producer under the Waste Electrical and Electronic Equipment Regulations 2007.
* Not all Windows Vista features are available for use on all Windows Vista Capable PCs. All Windows Vista Capable PCs will run the core experiences of Windows Vista, such as innovations in organizing and finding information, security, and reliability. Some features available in premium editions of Windows Vista -- like the new Windows Aero user interface -- require advanced or additional hardware. Check
http://www.windowsvista.com/getready for details.
