    Fix HP Printer issue on macOS
HP Officejet J3600 All-in-One Series Printers - Replacing the Cartridges
Follow the instructions below to replace the cartridges.
Replacing the cartridges
Step one: Remove the old cartridge
  1. Make sure that the product is turned on.
    If the product is off when the cartridge door is opened in order to access the print cartridges, it will not release the cartridges. Trying to remove the cartridges if they are not released might damage the product.
  2. Open the cartridge door. The carriage moves to the far right side of the product.
    Figure : Open the cartridge door
  3. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it.
    If you are replacing the tri-color cartridge, remove the cartridge from the slot on the left.
    If you are replacing the black cartridge, remove the cartridge from the slot on the right.
    Figure : Press down lightly on a cartridge to release it
  4. Pull the print cartridge out of its slot and toward you.
  5. If you are removing the cartridge because it is low or out of ink, recycle the cartridge.
Step two: Install the new print cartridges
  1. Remove the new cartridge from its package and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
      Figure : Remove the plastic tape
    1. Copper-colored electrical contacts
    2. Pink pull tab
    3. Ink nozzles under tape
    Do not touch the copper-colored electrical contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the copper-colored electrical contacts or the ink nozzles
  2. Slide the new cartridge forward into the empty slot.
    If you are installing a tri-color cartridge, slide it into the left slot.
    If you are installing a black cartridge, slide it into the right slot.
    Figure : Slide the new cartridge into the empty slot
  3. Press the cartridge firmly into the slot until it clicks into place.
    Figure : Press the cartridge in firmly
    When installing the cartridge and pressing it into the slot, do not rest your hand on top of the product for leverage. This might cause the carriage to lift out of position.
    Figure : Do not grasp the top of the product for leverage
  4. Close the cartridge door.
Step three: Align the new cartridges
The product prompts you to align the cartridges every time you install a new cartridge. Aligning the cartridges ensures high-quality output.
  1. Make sure that only plain, unused, white, U.S. letter or A4 size paper is loaded in the input tray.
  2. On the product control panel, press OK.
  3. The product calibrates itself and prints a test page. Recycle or discard the page.
    If colored paper is loaded in the input tray when the cartridges are aligned, the alignment fails. Load plain, unused, white, U.S. letter or A4 size paper into the input tray, and then follow these steps to try the alignment again.
    1. Load plain, unused, white, U.S. letter or A4 size paper into the input tray.
    2. On the control panel, press Setup.
    3. Press 6 to select Tools, and then press 2 to select Align Print Cartridge.
    4. The product prints a test page and calibrates the printer. Recycle or discard the page.
    If the alignment fails a second time, there might be a problem with the sensor or with the cartridge. Continue with 'Step four: Service the product.'
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
