HP Photosmart C7200 All-in-One Series - Printing Fax Confirmation Reports
You can set up the HP All-in-One to print confirmation reports automatically for each fax that is sent and received.
Printing a fax confirmation report
Follow these instructions to enable printed fax confirmation before sending any faxes. Select either On Fax Send or Send and Receive.
  1. Press Setup.
  2. Press the Down arrow () to highlight Print Report, then press OK.
  3. Press the Down arrow () to highlight Fax Confirmation, then press OK.
  4. Press the Down arrow () to select one of the following options in the table below, then press OK.
    Option
    On Fax Send
    Prints a fax confirmation report for every fax you send.
    On Fax Receive
    Prints a fax confirmation report for every fax you receive.
    Send and Receive
    Prints a fax confirmation report for every fax you send and receive.
    Off
    Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
