    Fix HP Printer issue on macOS
HP iPAQ 500 Voice Messenger Series - Using Messaging
Composing and Sending Messages
To compose a New Text Message:
  1. Press Start > Messaging.
  2. Press Menu > New and navigate to highlight the text area. Enter your text.
  3. In the message list, press Menu > Switch Accounts and select the account to compose a message.
To send Pictures/Videos using MMS:
  1. Press Start > Messaging > MMS.
  2. Press Menu > New.
  3. Navigate to highlight Insert picture area.
  4. Press the Action button and navigate to add the required image.
  5. Select a recipient, enter a subject and then press Send.
To add preset or recorded audio (except when video already exists):
  1. Navigate to highlight Insert Audio area.
  2. Press the Action button to open the Audio folder and navigate to select a required audio clip.
  3. Press Select to attach the audio clip.
If you are working offline, e-mail messages are moved to the Outbox folder and are sent the next time you connect.
Replying to or Forwarding a Message
  1. Press the Action button to open the selected message, and then press Menu > Reply,Reply All, or Menu > Forward.
  2. Enter your response. To quickly add common messages, press Menu > My Text and navigate to select a required message.
  3. Press Send.
Adding an Attachment to a Message
  1. In an open message, Press Menu > Insert and select the item you want to attach: Picture, Voice Note, or File.
Embedded objects cannot be attached to messages.
Downloading Messages
The manner in which you download messages depends on the type of account you have:
  1. To send and receive e-mail for an Outlook E-mail account, begin synchronization through ActiveSync.
  2. Text messages are automatically received when your phone is turned on. When your phone is turned off (in flight mode), messages are held by your service provider until the next time your phone is turned on.
By default, messages you send are not saved on your device to help conserve memory. If you want to keep copies of sent messages in your Outlook E-mail messaging list, press Menu > Tools > Options > Message, and select the Keep copies of sent items in Sent folder check box. If your account is an IMAP4 account, press Menu > Folders and navigate to select the Sent Items folder check box. Press Sync to synchronize this folder.
Downloading Messages from a Server
  1. On the message list, press Menu > Tools > Switch Accounts and select the account you want to use.
  2. Press Menu > Send/Receive. The messages on your device and e-mail server are synchronized: new messages are downloaded to the device Inbox folder, messages in the device Outbox folder are sent, and messages that have been deleted from the server are removed from the device Inbox folder.
