HP Designjet Z6100 Printer Series - Change the graphic language setting
Unless you are troubleshooting one of the problems mentioned in the following section, you should not need to change the default graphic language setting (Automatic). Avoid changing the setting because setting a specific graphic language means that you can print only files that have been created in that language.
Any setting selected in HP Easy Printer Care (Windows) or HP Printer Utility (Mac OS) overrides the setting selected on the front panel.
Use the front panel
To change the graphic language setting, select the Setup icon, and then select Printing preferences, Select graphics language, where the following options are available.
Figure : Front panel graphic language menu
  • Select Automatic to allow the printer determine which type of file it is receiving. This setting works for most software programs.
  • Select PS if you are printing only PostScript files, and if your PostScript jobs do not start with the standard PostScript header (%!PS) and do not include PJL language-switching commands
    Alternatively, select PS if you have experienced problems while downloading PostScript fonts. In this case, select Automatic again after you have downloaded the fonts.
    If you are downloading fonts over a USB connection, select the Setup icon, and then select Printing preferences, PS, Select encoding.
  • Select TIFF, JPEG, PDF, or CALS G4 only if you are sending a file of the appropriate type directly to the printer without going through a printer driver. This is normally done only through the Embedded Web Server, which sets the language without user intervention.
The PS and PDF options are available with PostScript printers only.
Use the HP Easy Printer Care (Windows) or HP Printer Utility (Mac OS)
Change the graphic language setting from the HP Easy Printer Care and HP Printer Utility by using the following steps.
  1. In Windows, click the Settings tab and then select Printer settings, Printing preferences.
    In Mac OS, select Configuration and then select Printer settings, Configure printer settings, Printing preferences.
  2. Select one of the following options:
    • Select Automatic to allow the printer determine which type of file it is receiving. This setting works for most software programs. Automatic is the recommended value.
    • Select HP-GL/2 only if you are sending a file of the appropriate type directly to the printer, without going through a printer driver
