HP Designjet Z6100 Printer Series - Remove top and bottom blank areas
In addition to the page margins set for the job, the printer allows 5 millimeters of blank space between each print. To remove these top and bottom blank areas, select the Remove top/bottom blank areas feature.
Be aware that when you submit more than one job at a time by clicking the Add files button in the Embedded Web Server, all of the jobs that you submit will adopt the settings of the final job that you submit. However, none of the jobs in the print queue are affected.
Use the Embedded Web Server
To remove top and bottom blank areas through the Embedded Web Server, go to the Submit Job page on the Main tab. In the Job Settings tree, select Advanced settings, Roll options and then select Remove top/bottom blank areas.
Use a driver
  • In the Windows driver, go to the Features tab and select Remove top/bottom blank areas.
  • In the Mac OS Print dialog box, go to the Finishing panel and select Remove top/bottom blank areas.
