HP Designjet Z6100 Printer Series - Print a mirror image
If you are using clear imaging paper, sometimes called backlit, you might want to print a mirror image of your image, so that when the paper is lit from behind, the image appears in the correct orientation. Use one of the following methods to do this without changing the image in your software program.
Use the Embedded Web Server
To print a mirror image through the Embedded Web Server, go to the Submit Job page on the Main tab. In the Job Settings tree, select Advanced settings, Transformations and then select one of the settings from the Mirror image drop-down menu.
Be aware that when you submit more than one job at a time by clicking the Add files button in the Embedded Web Server, all of the jobs that you submit will adopt the settings of the final job that you submit. However, none of the jobs in the print queue are affected.
