HP Compaq 6510b Notebook PC Specifications
Product description
The highly mobile HP Compaq 6510b Notebook PC helps keep you connected and productive so your office goes with you. This feature-packed notebook offers the latest Intel Core2 Duo processors and is compatible with a range of award-winning HP Universal Accessories for a complete business solution around the corner or across the globe.
Product features
Feature
Specification
Processor
Intel Core2 Duo (up to 2.4-GHz, up to 4-MB L2 cache)
Mobile Intel GM965
Memory
DDR2 SDRAM, 667-MHz, two slots supporting dual channel memory, 512/1024/2048-MB SODIMMs, up to 4096-MB total.
Hard drive(s)
SATA 80/120/160-GB 5400 rpm, 80-GB 7200 rpm, HP 3D DriveGuard
Removable media
12.7-mm optical drives: DVD+/–RW SuperMulti DL LightScribe, DVD+/–RW SuperMulti DL, DVD/CD-RW Combo, DVD-ROM
14.1-inch diagonal WXGA (1280 x 800 and 16M colors)
14.1-inch diagonal WXGA BrightView (1280 x 800 and 16M colors)
Graphics
Intel GMA X3100, up to 384-MB shared system memory
Audio
High Definition Audio, stereo speakers, stereo headphone/line out, stereo microphone in, integrated mono microphone
Wireless support
Optional HP ev2200 1xEV-DO Broadband Wireless Module (requires Verizon Wireless Service), optional HP hs2300 HSDPA Broadband Wireless Module (requires mobile network operator service); Intel 802.11a/b/g/draft-n, a/b/g, b/g, Broadcom 802.11a/b/g/draft-n, a/b/g, b/g, Bluetooth 2.0, HP Wireless Assistant
Communications
Broadcom NetLink Gigabit Ethernet PCI Controller10 (10/100/1000 NIC), 56K v.92 modem
1 Type I/II PC Card slot supports 32-bit CardBus and 16-bit cards, Media Card Reader
Ports and connectors
4 USB 2.0 ports, VGA, stereo microphone in, stereo headphone/line out, 1394a, power connector, RJ-11/modem, RJ-45/ethernet, S-video TV out, docking connector, secondary battery connector
Input device
Full-sized keyboard, Touchpad with scroll zone
HP Backup and Recovery Manager, Roxio Creator 9, Microsoft Office 2007 Small Business or Professional (optional)
Security
HP ProtectTools, TPM Embedded Security Chip 1.2,13 HP Fingerprint Sensor, Symantec Norton Internet Security, optional Smart Card Reader,12 Kensington lock, HP Privacy Filter (optional)
Dimensions
(h × w × d)
1.33 in (at front) x 13.03 in x 9.57 in / 33.8 mm (at front) x 330.9 mm x 243.1 mm
starting at weight: 5.0 lbs / 2.27 kg (weight will vary by configuration)
Power
6-cell (55 WHr) Lithium-Ion battery, 6-cell (47 WHr) Lithium-Ion battery, optional HP (52 WHr) Extended Life Battery,12 optional HP (95 WHr) Ultra-Capacity Battery,12 90W HP Smart AC Adapter, HP Fast Charge11
Expansion solutions
HP 3-in-1 NAS Docking Station, HP Advanced Docking Station, HP Docking Station, HP Monitor Stand, HP Adjustable Notebook Stand, HP External MultiBay II
Limited 3-year,1-year and 90-day warranty options available depending on country, 1-year limited warranty on primary battery
Computer specifications
Metric
U.S.
Dimensions
Height (front to back)
3.39 to 3.95 cm
1.32 to 1.56 in
Width
33.1 cm
13.03 in
Depth
24.3 cm
9.57 in
Weight (with optical drive, hard drive, and battery)
2.44 kg
5.38 lbs
Input power
Operating voltage
19.0 V dc @ 4.74 A – 90 W
Operating current
4.74 A
Temperature
Operating (not writing to optical disc)
0°C to 35°C
32°F to 95°F
Operating (writing to optical disc)
5°C to 35°C
41°F to 95°F
Nonoperating
-20°C to 60°C
-4°F to 140°F
Relative humidity
Operating
10% to 90%
Nonoperating
5% to 95%
Maximum altitude (unpressurized)
Operating (14.7 to 10.1 psia)
-15 m to 3,048 m
-50 ft to 10,000 ft
Nonoperating (14.7 to 4.4 psia)
-15 m to 12,192 m
-50 ft to 40,000 ft
Shock
Operating
125 g, 2 ms, half-sine
Nonoperating
200 g, 2 ms, half-sine
Random vibration
Operating
0.75 g zero-to-peak, 10 Hz to 500 Hz, 0.25 oct/min sweep rate
Nonoperating
1.50 g zero-to-peak, 10 Hz to 500 Hz, 0.5 oct/min sweep rate
Applicable product safety standards specify thermal limits for plastic surfaces. The computer operates well within this range of temperatures.
14.1-inch, WXGA+ display specifications
Metric
U.S.
Dimensions
Height
21.3 cm
8.40 in
Width
28.5 cm
11.20 in
Diagonal
35.8 cm
14.10 in
Number of colors
Up to 16.8 million
Contrast ratio
200:1 (typical)
Brightness
180 nits (typical)
Pixel resolution
Pitch
0.259 × 0.259 mm
Format
1440 × 900
Configuration
RGB vertical stripe
Backlight
CCFT
Character display
80 × 25
Total power consumption
6.5.0 W
Viewing angle
+/-45° horizontal, +15/-35° vertical (typical)
Hard drive specifications
160-GB*
120-GB*
80-GB*
Dimensions
Height
9.5 mm
9.5 mm
9.5 mm
Width
70 mm
70 mm
70 mm
101 g
101 g
101 g
Interface type
SATA
SATA
SATA
Transfer rate
100 MB/sec
100 MB/sec
100 MB/sec
Security
ATA security
ATA security
ATA security
Seek times (typical read, including setting)
Single track
3 ms
3 ms
3 ms
Average
13 ms
13 ms
13 ms
Maximum
24 ms
24 ms
24 ms
Logical blocks
312,560,640
234,420,480
156,280,320
Disc rotational speed
5400 rpm
5400 rpm
7200 and 5400 rpm
Operating temperature
5°C to 55°C (41°F to 131°F)
*1 GB = 1 billion bytes when referring to hard drive storage capacity. Actual accessible capacity is less. Actual drive specifications may differ slightly.
Certain restrictions and exclusions apply. Contact technical support for details.
Primary 6-cell, Li-ion battery specifications
Metric
U.S.
Dimensions
Height
2.0 cm
0.79 in
Width
20.3 cm
7.99 in
Depth
5.3 cm
2.09 in
0.34 kg
0.75 lb
Energy
Voltage
14.4 V
Amp-hour capacity
2.2 Ah and 2.55 Ah
Watt-hour capacity
47 Wh and 55Wh
Temperature
Operating
5°C to 45°C
41°F to 113°F
Nonoperating
0°C to 60°C
32°F to 140°F
DVD±RW and CD-RW Super Multi Double-Layer Combo Drive specifications
Read:
Write:
Applicable disc
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
CD-R and CD-RW
DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM
Center hole diameter
1.5 cm (0.59 in)
Disc diameter
Standard disc
12 cm (4.72 in)
Mini disc
8 cm (3.15 in)
Disc thickness
1.2 mm (0.047 in)
Track pitch
0.74 µm
Access time
CD
DVD
Random
< 175 ms
< 230 ms
Full stroke
< 285 ms
< 335 ms
Audio output level
Line-out, 0.7 Vrms
Cache buffer
2 MB
Data transfer rate
24X CD-ROM
3,600 KB/sec
8X DVD-ROM
10,800 KB/sec
24X CD-R
3,600 KB/sec
16X CD-RW
2,400 KB/sec
8X DVD+R
10,800 KB/sec
4X DVD+RW
5,400 KB/sec
8X DVD-R
10,800 KB/sec
4X DVD-RW
5,400 KB/sec
2.4X DVD+R(9)
2,700 KB/sec
5X DVD-RAM
6,750 KB/sec
Transfer mode
Multiword DMA Mode
Startup time
< 15 seconds
Stop time
< 6 seconds
DVD/CD-RW Combo Drive specifications
Read:
Write:
Applicable disc
CD-R and CD-RW
1.5 cm (0.59 in)
Disc diameter
Standard disc
12 cm (4.72 in)
Mini disc
8 cm (3.15 in)
Disc thickness
1.2 mm (0.047 in)
Track pitch
0.74 µm
Access time
CD
DVD
Random
< 110 ms
< 130 ms
Full stroke
< 210 ms
< 225 ms
Audio output level
Line-out, 0.7 Vrms
Cache buffer
2 MB
Data transfer rate
24X CD-ROM
3,600 KB/sec
8X DVD
3,600 KB/sec
24X CD-R
3,600 KB/sec
24X CD-RW
3,600 KB/sec
Transfer mode
Multiword DMA mode 2
Startup time
< 15 seconds
Stop time
< 6 seconds
DVD-ROM drive
Applicable disc
DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18, CD-ROM (Mode 1 and 2), CD Digital Audio, CD-XA ready (Mode 2, Form 1 and Form 2), CD-I (Mode 2, Form 1 and Form 2), CD-R, CD-RW, Photo CD (single and multisession), CD-Bridge
1.5 cm (0.59 in)
Disc diameter
Standard disc
Mini disc
12 cm (4.72 in)
8 cm (3.15 in)
Disc thickness
1.2 mm (0.047 in)
Track pitch
0.74 µm
Access time
CD
DVD
Random
< 100 ms
< 125 ms
Full stroke
< 175 ms
< 225 ms
Audio output level
Line-out, 0.7 Vrms
Cache buffer
512 KB
Data transfer rate
CD-R (24X)
3600 KB/s (150 KB/s at 1X CD rate)
CD-RW (10X)
1500 KB/s (150 KB/s at 1X CD rate)
CD-ROM (24X)
DVD (8X)
10,800 KB/s (1,352 KB/s at 1X DVD rate)
16.6 MB/s
Startup time
< 10 seconds
Stop time
< 3 seconds
System DMA specifications
Hardware DMA
System function
DMA0
Not applicable
DMA1*
Not applicable
DMA2*
Not applicable
DMA3
Not applicable
DMA4
Direct memory access controller
DMA5*
Available for PC Card
DMA6
Not assigned
DMA7
Not assigned
*PC Card controller can use DMA 1, 2, or 5.
System interrupt specifications
Hardware IRQ
System function
IRQ0
System timer
IRQ1
Standard 101-/102-Key or Microsoft® Natural Keyboard
IRQ2
Cascaded
IRQ3
Intel 82801DB/DBM USB2 Enhanced Host Controller—24CD
IRQ4
COM1
IRQ5*
Conexant AC—Link Audio Intel 82801DB/DBM SMBus Controller—24C3 Data Fax Modem with SmartCP
IRQ6
Diskette drive
IRQ7*
Parallel port
IRQ8
System CMOS/real-time clock
IRQ9*
Microsoft ACPI-compliant system
IRQ10*
Intel USB UHCI controller—24C2
Intel 82852/82855 GM/GME Graphic Controller
Realtek RTL8139 Family PCI Fast Ethernet Controller
IRQ11
Intel USB EHCI controller—24CD
Intel USB UHCI controller—24C4
Intel USB UHCI controller—24C7
Intel Pro/Wireless 2200BG
TI OHCI 1394 host controller
TI PCI1410 CardBus controller
IRQ12
Synaptics PS/2 TouchPad
IRQ13
Numeric data processor
IRQ14
Primary IDE channel
IRQ15
Secondary IDE channel
*Default configuration; audio possible configurations are IRQ5, IRQ7, IRQ9, IRQ10, or none.
PC Cards may assert IRQ3, IRQ4, IRQ5, IRQ7, IRQ9, IRQ10, IRQ11, or IRQ15. Either the infrared or the serial port may assert IRQ3 or IRQ4.
System I/O address specifications
I/O address (hex)
System function (shipping configuration)
000 - 00F
DMA controller no. 1
010 - 01F
Unused
020 - 021
Interrupt controller no. 1
022 - 024
Opti chipset configuration registers
025 - 03F
Unused
02E - 02F
87334 “Super I/O” configuration for CPU
040 - 05F
Counter/timer registers
044 - 05F
Unused
060
Keyboard controller
061
Port B
062 - 063
Unused
064
Keyboard controller
065 - 06F
Unused
070 - 071
NMI enable/RTC
072 - 07F
Unused
080 - 08F
DMA page registers
090 - 091
Unused
092
Port A
093 - 09F
Unused
0A0 - 0A1
Interrupt controller no. 2
0A2 - 0BF
Unused
0C0 - 0DF
DMA controller no. 2
0E0 - 0EF
Unused
0F0 - 0F1
Coprocessor busy clear/reset
0F2 - 0FF
Unused
100 - 16F
Unused
170 - 177
Secondary fixed disk controller
178 - 1EF
Unused
1F0 - 1F7
Primary fixed disk controller
1F8 - 200
Unused
201
JoyStick (decoded in ESS1688)
202 - 21F
Unused
220 - 22F
Entertainment audio
230 - 26D
Unused
26E - 26
Unused
278 - 27F
Unused
280 - 2AB
Unused
2A0 - 2A7
Unused
2A8 - 2E7
Unused
2E8 - 2EF
Reserved serial port
2F0 - 2F7
Unused
2F8 - 2FF
Infrared port
300 - 31F
Unused
320 - 36F
Unused
370 - 377
Secondary diskette drive controller
378 - 37F
Parallel port (LPT1/default)
380 - 387
Unused
388 - 38B
FM synthesizer—OPL3
38C - 3AF
Unused
3B0 - 3BB
VGA
3BC - 3BF
Reserved (parallel port/no EPP support)
3C0 - 3DF
VGA
3E0 - 3E1
PC Card controller in CPU
3E2 - 3E3
Unused
3E8 - 3EF
Internal modem
3F0 - 3F7
“A” diskette controller
3F8 - 3FF
Serial port (COM1/default)
CF8 - CFB
PCI configuration index register (PCIDIVO-1)
CFC - CFF
PCI configuration data register (PCIDIVO-1)
System memory map specifications
Size
Memory address
System function
640 KB
00000000-0009FFFF
Base memory
128 KB
000A0000-000BFFFF
Video memory
48 KB
000C0000-000CBFFF
Video BIOS
160 KB
000C8000-000E7FFF
Unused
64 KB
000E8000-000FFFFF
System BIOS
15 MB
00100000-00FFFFFF
Extended memory
58 MB
04800000-07FFFFFF
Super extended memory
58 MB
04800000-07FFFFFF
Unused
2 MB
08000000-080FFFFF
Video memory (direct access)
4 GB
08200000-FFFEFFFF
Unused
64 KB
FFFF0000-FFFFFFFF
System BIOS
Software/OS
Feature
Preinstalled
  • Genuine Windows Vista Business 32/64
  • Genuine Windows Vista Home Basic
  • Genuine Windows XP Professional
  • FreeDOS
Supported
Genuine Windows Vista Enterprise
Certified
SuSe Linux Enterprise Desktop 10
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
