Use the HP MFP Send Fax driver software to send fax jobs from the computer to the device over a network. The fax driver is installed on the client computer.
This STR provides information about the HP MFP Send Fax driver that is used with the HP Analog Fax Accessory when it is installed in the HP CM8060/CM8050 Color MFP with Edgeline Technology.
The following operating systems support this driver:
Windows XP
Windows Server 2003
Windows 2000
For additional information, see the HP CM8060/CM8050 Color MFP with Edgeline Technology System Administrator Guide, which is available on the System Administrator's CD.
