HP CM8060/CM8050 Color MFP with Edgeline Technology - Send faxes
  1. Place the original document face-down on the glass or face-up in the document feeder.
  2. From the Home screen, touch Fax to open the fax feature.
  3. You can send a fax to a single recipient or to multiple recipients.
    Specify the fax numbers by using one or both of these methods:
    Type the fax number manually
    From the Fax screen, touch the box below Fax Number: to open the virtual keypad. Type the fax number.
    Touch Pause to indicate a required pause.
    To delete a character, touch the backspace button ().
    Use a speed dial
    From the Fax screen, select the speed-dial code from the list or touch the box below Speed Dial Code: and type the speed-dial code.
    To search for a speed dial, touch the search button ().
  4. Touch OK to return to the main fax screen. To transfer the number into the fax recipients list, touch the down arrow button ().
  5. Touch More Options to see other fax options. For more information about using customized settings, see Configure the fax options for each job.
  6. After all the options are set, touch Send Fax () to scan the document and send the fax.
  7. To verify if the fax was sent successfully, open the Home screen and touch Job Status. Touch the Job Log tab, and look for the fax in the list of completed jobs.
