Configuration
Height
Width
Depth
HP CM8050/8060 MFP with the HP single output bin
1220 mm (48 inches)
1500 mm (59 inches)
840 mm (33 inches)
HP CM8050/8060 MFP with the HP single output bin and HP 4000-sheet input tray
1220 mm (48 inches)
1680 mm (66 inches)
840 mm (33 inches)
HP CM8050/8060 MFP with an HP multifunction finisher
1250 mm (49 inches)
1980 mm (78 inches)
840 mm (33 inches)
HP CM8050/8060 MFP with an HP 4-bin job separator
1220 mm (48 inches)
1730 mm (68 inches)
840 mm (33 inches)
HP CM8050/8060 MFP with HP 4000-sheet input tray and an HP multifunction finisher
1250 mm (49 inches)
2160 mm (85 inches)
840 mm (33 inches)
HP CM8050/8060 MFP with HP 4000-sheet input tray and an HP 4-bin job separator
1220 mm (48 inches)
1910 mm (75 inches)
840 mm (33 inches)
Configuration
Height
Width
Depth
1620 mm (64 inches)
1700 mm (67 inches) to
2030 mm (80 inches)
1600 mm (63 inches)
1620 mm (64 inches)
1930 mm (76 inches) to
2540 mm (100 inches)
1600 mm (63 inches)
1620 mm (64 inches)
2540 mm (100 inches) to
2870 mm (113 inches)
1600 mm (63 inches)
1620 mm (64 inches)
2290 mm (90 inches) to
2620 mm (103 inches)
1600 mm (63 inches)
1620 mm (64 inches)
2740 mm (108 inches) to
3350 mm (132 inches)
1600 mm (63 inches)
1620 mm (64 inches)
2490 mm (98 inches) to
3100 mm (122 inches)
1600 mm (63 inches)
*The approximate space required around the HP CM8050/8060 MFP and accessories for operator clearance.
Configuration
Height
Width
Depth
2130 mm (84 inches)
1700 mm (67 inches) to 2210 mm (87 inches)
1910 mm (75 inches) to
2130 mm (84 inches)
2080 mm (82 inches) to
2720 mm (107 inches)
2130 mm (84 inches)
2540 mm (100 inches) to 3050 mm (120 inches)
2130 mm (84 inches)
2290 mm (90 inches) to 2790 mm (110 inches)
2130 mm (84 inches)
2900 mm (114 inches) to
3530 mm (139 inches)
2130 mm (84 inches)
2640 mm (104 inches) to
3280 mm (129 inches)
*The approximate space required around the HP CM8050/8060 MFP and accessories for service access and service personnel clearance.
