Issue
Cause
Solution
All users are unable to store jobs in the network folder.
A firewall might be interfering.
If IPsec is enabled, it could be interfering with digital-send features. Try disabling IPsec. See Networking and I/O menu.
The server might be turned off.
Verify that the server is turned on.
A particular user is unable to store jobs in the network folder.
The folder might have restrictions on who can write to it.
If write-access is controlled for the folder, you must sign in again to save a file to that folder.
If you are trying to send the job to a folder that is not one of the Quick Access folders, the path to the folder might not be correct.
Verify that you have typed the correct network path.
If you specified a folder by editing the path to a Quick Access Folder, you might not have permission for the new folder.
Make sure you have permission to store jobs in this folder.
The user might not be authenticated to the network server.
Verify that the user has the required credentials to access the server where the network folder resides.
The user might have specified a file type that is not supported.
Try saving the file with a different file-type extension.
No notification was received, although the option to receive a notification was selected.
The default e-mail address for notifications might not be set, or it might be incorrect.
Sign in to the device, and verify that the e-mail address for the notification option is correct.
- ${title}
- ${title}
- ${title}
- ${title}
HP CM8060/CM8050 Color MFP with Edgeline Technology - Problems with sending to a network folder
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
