HP Designjet Z3100ps Photo Printer Series - Printer software
The following software is provided with your printer:
  • The PCL3 raster driver
  • The RTL and HP-GL/2 driver for Microsoft Windows
  • The PostScript driver
  • The HP Easy Printer Care (Microsoft Windows) or HP Printer Utility (Macintosh OS), allows you to:
    • Manage the printer including color with the HP Color Center
    • Manage the job queue
    • View the status of the ink cartridges, the printheads, and the paper
    • View job accounting information
    • Update the printer's firmware
    • Access the HP Knowledge Center
    • Change various printer settings (in the Settings tab)
    • Perform calibrations and troubleshooting
  • The Embedded Web Server, runs in the printer and enables you to use a Web browser on any computer to check ink levels and printer status.
  • Advanced Profiling Solution included on separate DVD, to be installed after other HP software (drivers and printer utilities).
