HP CM8060/CM8050 Color MFP with Edgeline Technology - Features
Feature
Control panel
HP Easy Select control panel provides access to all features
Adjustable backlight
Numeric keypad plus five job-control hard keys
Sleep button to put the device into an energy saving Sleep mode
On/off button on the control panel
Paper handling
The standard input trays hold a total of up to 1,580 sheets of 75 g/m2 (20-lb bond) paper.
  • Tray 1 holds up to 80 sheets.
  • Trays 2–4 each hold up to 500 sheets.
The document feeder holds up to 100 sheets of 75 g/m2 (20-lb bond) paper.
The optional high-capacity input tray (Tray 5) holds up to 4,000 sheets of 75 g/m2 (20-lb bond) paper.
The single output bin holds up to 300 sheets of 75 g/m2 (20-lb bond) paper.
The optional finishing device holds a total of up to 3,700 sheets of 75 g/m2 (20-lb bond) paper.
  • Output Bins 1–2 each hold up to 400 sheets.
  • Output Bins 3–4 each hold up to 200 sheets.
  • Output Bin 5 holds up to 2,500 sheets.
Printer drivers
HP PCL 6
HP PCL 5c
HP postscript level 3 emulation
Fax driver
Fonts
93 internal fonts
Connectivity
Hi-Speed USB 2.0 cable interface
Host-USB
LAN (RJ-45)
Enhanced input/output (EIO) slot for adding an HP Jetdirect print server, a parallel port, or other accessories
Supplies
Customer-replaceable supplies include five ink cartridges.
The device provides supplies status information at the control panel, and an internal supplies-status page.
Memory
1024 MB of random access memory (RAM), standard. This is also the maximum memory for the device.
80 GB embedded hard disk
Accessories
Optional high-capacity input tray (Tray 5)
Optional HP Multifunction Finisher
Optional HP 4-Bin Job Separator
A variety of EIO accessories
HP analog fax accessory
For a complete list of accessories and part numbers, see Order supplies and accessories.
Accessibility
  • A complete, multipage copy or print job can be completed by using only one hand.
  • Paper can be loaded in all trays by using only one hand.
  • All ink cartridges can be replaced by using only one hand.
  • Most paper jams can be cleared by using only one hand, but clearing some jams might require two hands.
  • The font size for text on the control panel is at least 10.5 points (12 pixels).
  • The device provides audible feedback when you press the buttons.
