HP Designjet Z3100ps Photo Printer Series - Black Ink Comes Off When You Touch the Print
This problem may be caused by printing with matte black ink on glossy paper. The printer will not use matte black ink if it knows that the paper will not retain it. To be sure of avoiding matte black ink, you can select Photo Glossy Paper as the paper type (in the Photo Paper category).
