HP Photosmart A440 Series Printers - Product Specifications
This document outlines the product specifications for the HP Photosmart A440 Series printers.
Figure : HP Photosmart A440 series printer
Model numbers
HP Photosmart A440 Printer Dock
Q8507A
HP Photosmart A442 Printer Dock and M437 Digital Camera
Q8456A
HP Photosmart A446 Printer Dock and M537 Digital Camera
Q8508A
Minimum System requirements
Component
Windows
Macintosh
Windows XP Home, XP Professional, or x64 Edition
Mac ®OS X 10.3.x, 10.4.x
Processor
Intel® Pentium® II (or equivalent) or higher
G3 or greater
RAM
64MB (256MB recommended)
128MB
Free disk space
500MB
150MB
Video display
800 x 600 pixels, 16-bit or higher
CD-ROM drive
4x
4x
Browser
Microsoft Internet Explorer 5.5 or later
Not applicable
Printer specifications
Specification
Details
Connectivity
USB 2.0 full-speed: Windows XP Home, XP Professional, or x64 Edition; Mac OS X 10.3.x, 10.4.x
PictBridge: Using the front camera port
Image file formats
JPEG Baseline
Margins
Top: 0.0 mm (0.0 inches)
Bottom: 0.0 mm (0.0 inches)
Left: 0.0 mm (0.0 inches)
Right: 0.0 mm (0.0 inches)
Media sizes
Photo paper 10 x 15 cm (4 x 6 inches)
Photo paper with tab 10 x 15 cm with 1.25 cm tab (4 x 6 inches with 0.5 inch tab)
Panorama photo paper 10 x 30 cm (4 x 12 inches)
Index cards 10 x 15 cm (4 x 6 inches)
A6 cards 105 x 148 mm (4.1 x 5.8 inches)
L-size cards 90 x 127 mm (3.5 x 5 inches)
L-size cards with tab 90 x 127 mm with 12.5 mm tab (3.5 x 5 inches with 0.5 inch tab)
Hagaki cards 101 x 203 mm (4 x 8 inches)
Printing on Hagaki cards and Panorama photo paper is supported only when printing from a computer.
Media types
HP Advanced Photo Paper (recommended)
HP Premium Photo Paper
Cards (index, A6, L-size)
Paper tray
One 10 x 15 cm (4 x 6 inches) photo paper tray
Paper tray capacity
Up to 20 sheets of photo paper, maximum thickness 292 μm (11.5 mil) per sheet
Up to 10 sheets of 10 x 30 cm (4 x 12 inches) photo paper for panoramic printing
Ink cartridges
HP 110 tri-color Inkjet print cartridge
Physical dimensions
Dimension
Size
Height
158 mm (6.22 inches)
Width
465 mm (18.31 inches)
Depth
230 mm (9.06 inches)
4.2 kilograms (9.26 pounds)1
1Printer weight is calculated without the pens and the external power supply
Power specifications
Category
Specification
Power consumption
Printing: 14.4 W
Idle: 8.1 W (with camera docked)
Off: 6.2 W (with camera docked)
Idle and charging camera batteries: 25 W
Off and charging camera batteries: 22.9 W
Power Supply Model Number
HP Part # 0957–2121 (North America), 120 Vac (±10%) 60 Hz (±3 Hz)
HP Part # 0957–2120 (Rest of world), 100-240 Vac (±10%) 50/60 Hz (±3 Hz)
Environmental specifications
HP recommends using a Universal Serial Bus (USB) cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Recommended operating conditions
Parameter
Specification
Temperature
5 to 40 degrees C (41 to 104 degrees F)
Humidity
5 to 90 percent relative humidity non-condensing
Maximum operating conditions
Parameter
Specification
Temperature
15 to 35 degrees C (59 to 95 degrees F)
Humidity
20 to 80 percent relative humidity non-condensing
