HP Color LaserJet CM1015 MFP and CM1017 MFP Series Printers - Control Panel Error Messages
The following are control-panel warning icons that may be seen on the HP Color LaserJet CM1017 MFP.
Control-panel warning icons
Warning icons
General error
Memory card error
Paper error
Paper jam
Attention
Scanner error
The following tables display information about control-panel error messages. The messages are grouped by general error type.
For all supplies-related issues, open the front door of the MFP and perform a physical inspection of the cartridges for damage such as broken parts, gouges/scratches on the developer rolls, or excessive leaking. Replace the cartridge if any of the above are found. If possible, print a Configuration page and note any errors listed.
Supplies control-panel messages
HP supplies installed
Control Panel Message
HP supplies
installed
This message appears when non-HP toner cartridges have been replaced by genuine HP toner cartridges.
Action
No action required. If the error persists, verify that the E-label-reader guide pins are not broken.
10.000x Supply error
E-label cannot be read or print cartridge is not properly installed.
10.0000 = Black print cartridge
10.0001 = Cyan print cartridge
10.0002 = Magenta print cartridge
10.0003 = Yellow print cartridge
Action
  1. If a specific cartridge is identified as defective, replace that cartridge with a genuine HP cartridge that does not cause this error in another MFP.
  2. If the error continues, contact HP Support.
10.100x Supply error
Reinstall
The supplies gauge displays the consumption levels of print cartridges.
A print cartridge is missing.
10.1000 = Black print cartridge
10.1001 = Cyan print cartridge
10.1002 = Magenta print cartridge
10.1003 = Yellow print cartridge
Action
54.xx
Toner sensor error.
Action
Incorrect <color> cartridge
The <color> print cartridge may be crooked, or installed in the wrong print cartridge slot.
One of the following messages may be displayed:
Incorrect black cartridge
Incorrect cyan cartridge
Incorrect magenta cartridge
Incorrect yellow cartridge
Action
Install <color> cartridge
The supply gauge indicates the supply or supplies that are out of toner.
One of the following messages may display:
  • Install black cartridge
  • Install cyan cartridge
  • Install magenta cartridge
  • Install yellow cartridge
Action
Install supplies
Install supplies
Multiple supplies are not installed.
Action
Non-HP supply in use
Ready
A non-HP (cloned or refilled) supply has been installed and was overridden.
Action
Order supplies
Order supplies
Ready
Multiple supplies are low.
Action
Order supplies
Order supplies
The <color> print cartridge is low. One of the following messages may be displayed:
  • Order black cartridge. Ready light is On.
  • Order cyan cartridge. Ready light is On.
  • Order magenta cartridge. Ready light is On.
  • Order yellow cartridge. Ready light is On.
Action
Replace supplies
Replace supplies
The cartridge is out of toner.
Action
Replace supplies. Override in use.
Replace supplies.
Override in use.
Ready
The supplies gauge displays the consumption levels of print cartridges. This is the message that displays when the non-HP supply is first installed.
Supply override in use. The user has decided to continue printing beyond the out point. A supply is low and using Override may result in unsatisfactory print quality.
This message also displays the entire time multiple non-HP supplies are used in the MFP.
Action
Replace supply. Override in use.
Replace supply.
Override in use.
Ready
This message also displays the entire time a single non-HP supply is used. It displays after the Unauthorized Supply message displays and after the user presses the override.
Action
Non-HP <color> installed
A non-HP <color> cartridge is installed. Displays one of the following messages:
  • Non HP black installed. Press OK to accept.
  • Non HP magenta installed. Press OK to accept.
  • Non-HP cyan installed. Press OK to accept.
  • Non-HP yellow installed. Press OK to accept.
Action
Unauthorized supply in use
Unauthorized
supply in use
alternates with
Ready
Displays this message when the non-HP supply is first installed: A new non-HP supply has been installed and was overridden.
Action
Unauthorized color
Unauthorized <color>
A new non-HP supply has been installed. One of these four messages is displayed until an HP supply is installed or until OK is pressed.
  • Unauthorized black cartridge
  • Unauthorized magenta cartridge
  • Unauthorized cyan cartridge
  • Unauthorized yellow cartridge
Action
Paper-path control-panel messages
Jam
A jam occurred in:
  • print/paper path
  • tray 1
  • tray 2
  • output bin
Action
Use the following procedure to determine what is defective.
  1. Check all jam locations in the MFP. If the control panel displays any message except Load paper before any paper is loaded in the MFP, proceed to step 2.
  2. Check the paper path for small scraps of paper. Remove any that are found.
  3. If paper continually jams at the rear-jam clearance area, replace the face-up paper delivery assembly.
  4. If jams persist at the ETB, check the ETB for damage. Contact HP Support for assistance.
  5. If jams occur in the tray 1 and tray 2 input areas, replace the feed roll and separation pad.
  6. If the error message persists and verified that the correct type/size of paper is being used and there are no small scraps of paper in the paper path, contact HP Support.
Unexpected size in tray X
Unexpected size
in tray X
Unexpected paper size error. The media size loaded in the tray does not match the media size configured for the tray.
Action
Load paper
The HP Color LaserJet CM1015/CM1017 MFP is out of paper.
Action
Load Tray X [TYPE] [SIZE]
Load Tray X
[TYPE] [SIZE]
The MFP is processing the job, but the tray indicator is empty.
Action
No media pickup.
No media pickup.
Press [OK]
The print engine has failed to pick up a piece of media.
Action
  1. Evaluate the paper tray for damage and serviceability. Replace it if necessary.
  2. Replace the pickup roller and separation pad.
  3. If the problem persists, contact HP Support.
Manual feed
Manual feed
Press [OK]
The MFP is waiting for paper in the tray indicated.
Action
Hardware control-panel messages
50.x Fuser error
50.x Fuser error
The device has experienced an internal hardware error.
50.1 Fuser Error - low temperature
50.2 Fuser Error - high temperature
50.3 Fuser Error - slow fuser
Action
  1. Power-cycle the MFP.
  2. If the message persists, contact HP Support.
51.20 Error
51.20 Error
51.20 Error - black scanner error
51.21 Error - cyan scanner error
51.22 Error - magenta scanner error
51.23 Error - yellow scanner error
Action
  2. Verify that the flat-flex cable connecting the DC controller to the formatter is securely connected.
  3. If the message persists, contact HP Support.
55.0 Error
DC controller error. The device has experienced an internal hardware error.
Action
57 Fan Error
57 Fan Error
Turn Off and then turn On
The device has experienced a problem with its internal fan.
Action
59 motor error
59 motor error
Action
Device error
Device error
Press [OK]
An internal error occurred in the device.
Action
Door open
The MFP door is open.
Action
Engine communication error
The device experienced an internal communication error.
Action
Calibrating...
Calibrating...
The MFP is calibrating.
Action
  1. If the message is persistent, perform an NVRAM initialization.
Cleaning...
Cleaning...
The MFP is in cleaning mode.
Action
Firmware control-panel messages
79 Error
79 Error
The device has experienced an internal firmware error.
Action
  1. Verify that the most current firmware is installed on the MFP. Load the most current version if necessary.
  2. Power-cycle the MFP.
  3. If the message persists, perform an NVRAM initialization.
  4. If the message persists, contact HP Support.
Invalid entry
Invalid entry
Invalid data or response.
Action
  2. If the message persists regardless of which button is pressed, contact HP Support.
Memory is low. Press [OK]
The device memory has been almost completely filled or is full.
This error occurs most often when printing from a host PC. The printer test page might not produce this error.
Action
  2. Perform an NVRAM initialization.
  3. Add memory to the MFP.
Memory low.
Memory low.
Only one copy made.
The device does not have enough memory to complete the collated copy job.
Action
Page too complex
Page too complex
Press OK
The device could not print the current page because of its complexity.
Action
Misprint. Press [OK]
The printed pages have been incorrectly placed on the paper.
Action
Memory-card control-panel messages
Insert only 1 memory card at a time
More than one memory card has been inserted.
Action
  1. Verify that only one photo card is inserted.
  2. Verify that the card contains .JPG files. This is the only file format recognized by the MFP.
  3. Verify that the memory-card-reader LED illuminates when the card is inserted. Also verify that the graphical display indicates that the MFP is reading the card.
  4. Verify that the ribbon cable connecting the memory-card-reader assembly to the formatter is not damaged and is securely connected on both ends.
  5. If the message persists, contact HP Support.
Memory card is in backwards
The memory card was inserted backwards into the card slot.
Action
Memory card is unsupported
The memory card that is been inserted is not a type that is supported.
The HP Color LaserJet CM1017 MFP supports the following cards:
  • Compact flash
  • Ultra Compact flash
  • Smart Media
  • Memory Stick
  • Secure Digital
  • Multi Media Card
  • XD Card
Action
Unknown Memory Card Error
There is an issue with either the memory card or the device memory-card reader.
Action
Scanner control-panel messages
Scanning error
Scanning error
The device cannot transmit scan information to a computer.
The following errors can occur during scanning:
  • Scanner Error 1 = ScannerError_DarkFind
  • Scanner Error 2 = ScannerError_LMWTempFind
  • Scanner Error 3 = ScannerError_BulbWarmupFromOff
  • Scanner Error 4 = ScannerError_BulbWarmupFromCoarse
  • Scanner Error 5 = ScannerError_CalLabelFind
  • Scanner Error 6 = ScannerError_DocOriginFind
  • Scanner Error 7 = ScannerError_LMWFinalFind
  • Scanner Error 8 = ScannerError_CalLabelFindAfterScan
  • Scanner Error 9 = ScannerError_CalLabelFindPriorToStandby
  • Scanner Error 10 = ScannerError_DocOriginFindPriorToStandby
  • Scanner Error 11 = ScannerError_BulbWarmupFromStandby
  • Scanner Error 12 = Motor test failure (ERR_MTR_TEST)
  • Scanner Error 13 = Ram Wall failure (ERR_RAM_WALL)
  • Scanner Error 14 = LED test failure (ERR_LED_TEST)
Action
  1. If any of these messages appear, contact HP Support.
