    Windows 11 Upgrade Guide
Loading Paper for the HP Photosmart C4200 All-in-One Printer Series
This document provides instructions for loading paper in the HP All-in-One.
Load paper
  1. Pull out the tray extender.
  2. Slide the paper-width guide to its outermost position.
    Figure : Sliding the paper-width guide
    If you are using letter or A4 paper or smaller, make sure the tray extender is open all the way.
  3. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  4. Insert the stack of paper into the input tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops.
    Figure : Loading paper
    Make sure that the HP All-in-One is idle and silent when you load paper into the input tray. If the HP All-in-One is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the HP All-in-One to eject blank pages.
  5. Slide the paper-width guide inward until it stops at the edge of the paper.
    Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
    Figure : Moving paper-width guides inward
    When using legal-size paper, leave the tray extender closed.
