    Fix HP Printer issue on macOS
HP Deskjet D2300 and D2400 Printer Series - Blinking Power Light
Blinking Power light
The Power light () might blink (flash) or be off. This product has a Power light that is on continuously during normal printing functions and that blinks briefly when a print job is canceled. Otherwise, a blinking Power light indicates that the product requires maintenance, or is in an error state.
Figure : Blinking Power light
Image of the Power light blinking
The following sections describe the most common issues related to a blinking (flashing) Power light. Find the issue related to the error you are experiencing, and then follow the steps to resolve the issue.
If the HP software is installed, double-click the HP Printer Assistant icon on the desktop. Click Tools and Updates, click Maintenance, and then click any of the four main buttons. Printer Assistant checks the status of the product, and the error message displays. If you did not install the HP software or no error message displays on the computer, continue to the solutions to solve your issue.
Issue: The Power light blinks
The Power light blinks.
Issue: The Power light blinks when trying to print labels
The Power light blinks when trying to print labels. The product is not picking up labels or paper correctly.
Issue: The Power light blinks and there are missing lines or bands on the printout
The Power light blinks and there are missing lines or bands on the printout.
Issue: The Power light blinks and a message might display on the computer
The Power light blinks and a message might display on the computer.
How do I resolve this issue? The following sections describe the most common messages that might display on the computer in combination with a blinking Power light. Choose one of the following messages that displays on your computer, and then expand that section for solutions.
Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
