Brightness
Adjusts the brightness level of the screen. The factory default range is 90.
Contrast
Adjustable scale
Adjusts the contrast level of the screen. The factory default range is 80.
Image Control
Adjusts the screen image.
Auto Adjustment
Automatically adjusts the screen image.
Horizontal Position
Adjusts the position of the screen image left and right.
Vertical Position
Adjusts the position of the screen image up and down.
Custom Scaling
Selects the method on how displayed information on the monitor will be formatted. Select:
Fill to Screen - Image fills the entire screen and may look distorted or elongated because of non-proportional scaling of height and width.
Fill to Aspect Ratio - Image is sized to fit the screen and maintains proportional image.
One-to-one - Disables video scaling, displays an image that is smaller in size than the monitor’s capability and centers the image on the screen in the active viewing area.
Sharpness
Adjusts the screen image to look sharper or soft.
If the one-to-one custom scaling menu is selected, scaling is disabled and the sharpness feature will also be disabled.
Clock
Minimizes any vertical bars or strips visible on the screen background. Adjusting the Clock will also change the horizontal screen image.
Clock Phase
Adjusts the focus of the display. This adjustment allows you to remove any horizontal noise and clear or sharpen the image of characters.
Color
Selects the screen color. The factory default is 6500 K.
9300 K
Changes to slightly blueish white.
6500 K
Changes to slightly reddish white.
Custom Color
Selects and adjusts your own color scales:
R - sets your own red color levels
G - sets your own green color levels
B - sets your own blue color levels
sRGB
Sets your screen colors to adapt to the color standards used in the image technology industry.
Language
Selects the language in which the OSD menu is displayed. The factory default is English.
Management
Selects the power management features of the monitor.
Power Saver
Enables the power saving feature. Select:
The factory default is On.
Power On Recall
Restores power to the monitor following an unexpected removal of power. Select:
Mode Display
Displays the resolution, refresh rate and frequency information on the screen each time the OSD Main Menu is accessed. Select:
The factory default is Off.
Power-On Status Display
Displays the operating status of the monitor each time the monitor is powered on. Select the location to display the status to:
The factory default is Top.
DDC/CI Support
Allows the computer to control some OSD menu features such as brightness, contrast and color temperature. Set to:
Sleep Timer
Provides the timer adjustment menu options:
Set Current Time - sets the current time in hours and minutes.
Set Sleep Time - Sets the time you want to place the monitor in sleep mode.
Set on Time - Sets the time you want the monitor to wake up from sleep mode.
Timer - Sets the Sleep Timer feature On or Off. The default setting is Off
Sleep Now - Immediately sets the monitor to enter sleep mode.
OSD Control
Adjusts the position of the OSD menu on the screen.
Horizontal Position
Changes the viewing position of the OSD menu to the left or right area of the screen. The factory default range is 50.
Vertical Position
Changes the viewing position of the OSD menu to the top or bottom area of the screen. The factory default range is 50.
OSD Timeout
Sets the time duration in seconds that the OSD is visible after the last button is pressed. The factory default is 30 seconds.
OSD Transparency
Adjust to view the background information through the OSD.
Selects and displays important information about the monitor.
Current Settings
Provides the current input video mode.
Recommended Settings
Provides the recommended resolution mode and refresh rate for your monitor.
Serial Number
Reports the serial number of the monitor. The serial number is needed if contacting HP technical support.
Version
Reports the firmware version of the monitor.
Backlight hours
Reports the total hours of backlight operation.
Video Input Control
Selects the default or primary video input signal when the monitor is connected to two active and valid video sources. The monitor will automatically determine the video format. The default input selection is DVI.
DVI-D
Selects DVI-D input.
VGA
Selects VGA input.
Disable Input Auto-Switching
Keeps the monitor's video input selection at it's current setting. This menu selection is visible if the video input control is set to Enable Input Auto-switching.
Enable Input Auto-Switching
Automatically returns the monitor's video input to the default auto-switching mode. This menu selection is visible if the video input control is set to Disable Input Auto-switching.
Factory Reset
Returns all OSD menu settings to the factory default setting, except the Language setting.
Exit
Exits the OSD menu screen.
