HP LP2045w LCD Monitor - Technical Specifications
All performance specifications are provided by the component manufacturers. Performance specifications represent the highest specification of all HP's component manufacturers' typical level specifications for performance and actual performance may vary either higher or lower.
LP2045w Specifications
Type
20.1 inches
TFT LCD
51 cm
Viewable Image Size
20–inch diagonal
51 cm
Tilt
-5 to 30°
Swivel
-45 to 45°
Maximum Weight (Unpacked)
20.3 lbs.
9.2 kg
Dimensions (include base)
Height
Depth
Width
16.7 inches
8.7 inches
17.4
425.0 mm
220.0 mm
443.0 mm
Maximum Graphic Resolution
1680 x 1050 (75Hz) analog input
1680 x 1050 (75Hz) digital input
Text Mode
720 x 400
Dot Pitch
0.258 (H) x 0.258 (W) mm
Horizontal Frequency
30 to 94 kHz
Vertical Refresh Rate
48 to 85 Hz
Environmental Requirements Temperature
Operating Temperature
Storage Temperature
41 to 95° F
-4 to 140° F
5 to 35° C
-20 to +60° C
Relative Humidity
20 to 80%
Power Source
100 — 240 VAC, 50/60 Hz
Altitude:
Operating
Storage
0 to 12,000 feet
0 to 40,000 feet
0 to 3657.6 m
0 to 12192 m
Power Consumption (maximum)
<75 watts
Input Terminal
One DVI-D connector cable not included.
One VGA connector with cable included.
