HP Designjet Z3100 Photo Printer Series - Print in gray shades
You can convert all colors in your image to shades of gray in the following ways:
  • In your application program: many programs provide this option.
  • In the Windows driver dialog: go to the Color tab and look at the Color Options section. Select Print In Grayscale.
  • In the Mac OS Print dialog: go to the Paper Type/Quality panel and select Color, then select Print In Grayscale.
If you select Print In Grayscale when using glossy paper, you must also choose between Gray and Black inks only and Full set of inks.
  • Gray and Black inks only means that only gray and black inks are used in your grayscale print. This gives the most neutral shades of gray and is selected by default for all paper types.
  • Full set of inks means that a mix of different colors are used in your grayscale print. This may give a better result if you are experiencing bronzing on glossy paper with the Gray and Black inks only option.
Country: Flag Thailand
