    Looking for Site Help?
HP Designjet Z3100 Photo Printer Series - Select paper size
The paper size can be specified in the following ways.
The paper size specified here should be the paper size in which the document was created. It is possible to rescale the document to a different size for printing.
  • In the Windows driver dialog: select the Paper/Quality tab, then Document Size.
  • In the Mac OS Page Setup dialog: select your printer in the Format for popup menu, then Paper Size.
  • Using the front panel: select the Setup menu icon , then Printing preferences, Paper, Select paper size. This option is available only with the HP-GL/2 Upgrade.
    If the paper size is set from your computer, it overrides the paper size setting in the front panel.
To choose a non-standard paper size not shown in the list of paper sizes:
  • Under Windows, there are two different ways:
    • In the driver dialog, select Custom from the paper size list in the Paper/Quality tab, then specify the paper dimensions, then click Save to save your new paper size. To see your new custom size in the list of custom sizes, you need to exit the printer properties, then reenter them and use the More button.
    • From the Start menu, select Printers and Faxes, then from the File menu select Server Properties. In the Forms tab, check the Create a new form box, specify the name and dimensions of the new form, then click Save Form.
  • Under Mac OS X 10.4, select Paper Size, Manage Custom Sizes in the Page Setup dialog.
  • Under Mac OS X 10.2 or 10.3, select Settings, Custom Paper Size from the Page Setup dialog.
Country: Flag Thailand
