HP Designjet Z3100 Photo Printer Series - Change the sleep mode setting
If the printer is left switched on but unused for a certain period of time, it goes automatically into sleep mode to save power. The default is 30 minutes. To change the time the printer waits before it goes into sleep mode, press the Menu key to return to the main menu and select the Setup menu icon , then Advanced, Sleep mode wait time. Highlight the wait time you want and then press the OK key. You can set the time to 30, 60, 120, 150, 180, 210, or 240 minutes.
