HP Designjet Z3100 Photo Printer Series - Internal prints
The internal prints give various kinds of information about your printer. They can be requested from the front panel without using a computer.
Before requesting any internal print, make sure that paper is loaded (roll or sheet), and that the front panel displays the Ready message. The loaded paper should be at least A3 landscape (16.53 in or 42 cm wide); otherwise the print may be clipped.
To print any internal print, press the Menu key to return to the main menu, select the Internal Prints menu icon , then select the internal print you want.
The following internal prints are available:
  • Menu map: shows details of all the front-panel display menus
  • Configuration: shows all the current front-panel display settings
  • Usage report: shows estimates of the total number of prints, number of prints by paper type, number of prints by print-quality option, and total amount of ink used per color (the accuracy of these estimates is not guaranteed)
  • HP-GL/2 palette: shows the color or grayscale definitions in the currently selected color palette, requires the HP-GL/2 Upgrade
  • Service information: provides information needed by service engineers
