HP Designjet Z3100 Photo Printer Series - Safety precautions
The following precautions ensure the proper use of the printer and prevent the printer from being damaged. Follow these precautions at all times.
  • Use the power supply voltage specified on the nameplate. Avoid overloading the printer's electrical outlet with multiple devices.
  • Ensure the printer is well-grounded. Failure to ground the printer may result in electrical shock, fire, and susceptibility to electromagnetic interference.
  • Do not disassemble or repair the printer yourself. Contact your local HP Service Representative for service.
  • Use only the electrical cord supplied by HP with the printer. Do not damage, cut, or repair the power cord. A damaged power cord has risk of fire and electric shock. Replace a damaged power cord with an HP-approved power cord.
  • Do not allow metal or liquids (except those used in HP Cleaning Kits) to touch the internal parts of the printer. Doing so may cause fire, electric shock, or other serious hazards.
  • Turn Off the printer and unplug the power cable from the power outlet in any of the following cases:
    • When placing your hands inside the printer
    • If there is smoke or an unusual smell coming from the printer
    • If the printer is making an unusual noise not heard during normal operation
    • A piece of metal or a liquid (not part of cleaning and maintenance routines) touches internal parts of the printer
    • During an electrical (thunder/lightning) storm
    • During a power failure.
