Make a wireless connection between an HP all-in-one with built-in wireless networking capability and a functional wireless network with an access point (router) that is SecureEZSetup enabled.
- ${title}
- ${title}
- ${title}
- ${title}
HP Photosmart All-in-One Products - Using an Access Point (Router) with SecureEzSetup to Make a Wireless Connection Between the All-in-One and the Computer
Connecting the unit to the computer
Activate SecureEzSetup on the access point. Usually this is accomplished by pressing a button on the access point. Refer to the router or access point documentation for specific instructions.
Press the Setup button on the all-in-one.
Press the arrow buttons until Network displays and then press OK. The Network menu displays.
Press the arrow buttons until Wireless Setup Wizard displays and then press OK.
Follow the instructions in the Wireless Setup Wizard.
After the all-in-one connects to the network, install the product software on the computer.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
