HP LaserJet M1005 MFP - Loading media
The following sections describe how to load media into the different input trays.
Printing on wrinkled, folded, or damaged media can cause jams.
Loading documents to copy or scan
Use these instructions to load originals into the device for scanning.
  1. Lift the flatbed scanner cover.
  2. Place the original document face-down on the flatbed scanner with the upper-left corner of the document at the lower-right corner of the glass.
  3. Gently close the lid.
    The document is ready to be copied or scanned.
Loading input trays
Priority input tray
The priority input tray on the HP LaserJet M1005 MFP holds up to 10 sheets of media up to 80 g/m220 lb in weight or one envelope, transparency, or card. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media.
Main input tray (tray 1)
The main input tray holds up to 150 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media (15 mm 0.6 in or less stack height). Load media with the top forward and the side to be printed facing down. To prevent jams and skewing, always adjust the side and rear media guides.
When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps to prevent multiple sheets of media from feeding into the device, which can cause jams.
