HP Designjet Z2100 Photo Printer Series - Margin Options
By default, the printer leaves a 5 mm margin between the edges of the image and the edges of the paper (17 mm at the foot of a sheet of paper). However, this behavior can be changed in several ways.
  • In the Microsoft Windows driver dialog: Select the Paper/Quality tab and then the Layout button.
  • In the Mac OS Print dialog: Select the Paper Type/Quality panel and then Layout.
Then some of the following options will be displayed.
Under Mac OS, the available margins options depend on the paper size selected in the Page Setup dialog. For instance, for borderless printing select a paper size name that includes the words 'no margins'.
  • Standard - The image will be printed on a page of the size that is selected, with a narrow margin between the edges of the image and the edges of the paper. The image should be small enough to fit between the margins.
  • Oversize - The image will be printed on a page slightly larger than the size that is selected. If the margins are cut off, a selected page size will be left with no margins remaining between the image and the edges of the paper.
  • Clip Contents By Margins - The image will be printed on a page of the size that is selected, with a narrow margin between the edges of the image and the edges of the paper. In this case, if the image is the same size as the page, the printer assumes that the extreme edges of the image are either white or unimportant, and do not need to be printed. This may be useful when the image already contains a border.
  • Borderless - The image will be printed on a page of the size is selected, with no margins. The image is slightly enlarged to ensure that no margin is left between the edges of the image and the edges of the paper. If Automatically by Printer is selected, this enlargement is done automatically. If Manually in Application is selected, a custom page size must be selected slightly larger than the page on which it is intended to print. See also Print with no margins.
