HP iPAQ hx2700 Pocket PC Series - The Foldable Keyboard (FA677A) Does not Support Cyrillic Input
Issue:
iPAQ Foldable Keyboard does not support cyrillic input
Solution
The iPAQ and foldable keyboard comes with the standard layout and doesn't have different language layouts other than the ones that are built in. It has the capability to supports various layouts. But to use different languages, customer may need to install those layouts.
3rd party software may be used which resloves the customer issue. If the customer wants, he can try the trial version and if it works, it may be purchased. This software is no way related to HP and is a 3rd party s/w.
Please ask the customer to read the details carefully.
The link where customer can download it from : (click on "try now" in the left to download) http://microsoft.handango.com/PlatformProductDetail.jsp?siteId=75&productType=2&productId=27174&review=1
It is advisable for the customer to read the manual first (which is included in the download file) to learn how to use this s/w.
