HP Photosmart C5500 All-in-One, D6100, and D7300 Printer Series - Fixing Ink Smears or Streaks
This document is for the HP Photosmart C5540, C5550, C5570, C5580 All-in-One, and HP Photosmart D6160, D6163, D6168, D7345, D7355, D7360, D7363, D7368 printers.
Problem
The printer is working, but the printed output shows smears or streaks of ink.
Figure : Self test page showing ink smears
Step 1: Check your paper
Make sure you printed on fresh, unwrinkled paper. If you are sure you did, go to the next step.
Step 2: Run the clean print cartridges utility
Do not clean the printhead unnecessarily, as this wastes ink and shortens the life of the ink nozzles on the printhead.
  1. Make sure the printer is turned on and connected to the computer.
  2. Load letter or A4 unused plain white paper into the main tray.
  3. If you are using a Windows computer:
    1. From the Windows Start menu, select HP , and then select HP Solution Center .
    2. Click Settings . Select Print Settings , and then Printer Toolbox .
    3. Click Clean the Printheads and follow the onscreen instructions.
    If you are using a Macintosh:
    1. Click HP Device Manager in the Dock.
    2. From the Information and Settings pop-up menu, choose Maintain Printer.
    3. Click Launch Utility .
    4. In the Configuration Settings area of the HP Printer Utility window, click Clean , and then click Clean again in the right section of the window.
    If print quality still seems poor after you clean the printhead, try aligning the printer.
Step 3: Aligning the printer
  1. Load letter or A4 unused plain white paper into the main tray.
  2. If you are using a Windows computer:
    1. From the Windows Start menu, select HP, and then select HP Solution Center.
    2. Click Settings, Print Settings, and then click Printer Toolbox.
    3. Click Align the Printheads.
    4. Follow the onscreen instructions.
    3. Click Launch Utility.
    4. In the Configuration Settings area of the HP Printer Utility window, click Align.
If print quality problems still persist after cleaning and aligning, click Contact HP on this page for more support options.
