A 'Paper Jam' Error Displays on the HP Photosmart D6160, D6163, and D6168 Printer Series
Issue
The Paper Jam. Clear jam then press OK. error message appears on the computer.
Solution
Follow these steps to resolve the issue.
Step one: Remove any loose paper
Do not remove jammed paper at this stage.
  1. Remove all loose paper from the paper input tray.
  2. If the paper is visible part way through the front of the product, gently pull the paper to remove it out.
If the issue continues, proceed to the next step.
Step two: Clear the jam from the back of the printer
  warning:
Clear jammed paper from the back only. Clearing jams from the front can damage the product.
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Press the latch on the rear access door, and then remove the rear access door from the product.
    Figure : Remove the rear access door
  4. Remove all the paper that might be stuck.
    • If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper. If all the pieces of paper are not removed, more paper jams are likely to occur.
    • If printing labels, see if any labels are missing from the label sheet. If any labels are missing, locate them inside the product, and then remove them carefully.
      Figure : Rear access door removed
    1. Area to remove paper from
  5. Reinstall the rear access door.
  6. Reconnect the power cord into the back of the product.
  7. Turn on the product.
  8. Press the OK button.
Step three: Clean the rollers
  4. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
    Rotate the rollers up, away from the bottom of the product.
    This will feed any small loose pieces of paper out of the product, and will prevent damage during cleaning.
    Figure : Cleaning the paper rollers
  5. Allow the rollers to dry completely, and then replace the rear access door.
Step four: Open the top cover and clear the jam
  1. Open the print cartridge access door.
  2. Open the paper jam door located inside the print cartridge access door.
      Figure : Open the print cartridge access door
    1. Paper jam door
  3. Remove all the paper that might be stuck inside the paper jam door.
  4. Close the paper jam door.
  5. Close the print cartridge access door.
Step five: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
Cause
Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
  • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
  • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
  • Do not add paper while the product is printing.
  • Remove printed pages frequently.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Used paper might cause jams.
  • Make sure that the rear access door is securely fastened.
