HP Compaq nc/nx6300 Series Notebook PC - Specifications
Physical Specifications
Item
Specification
Dimensions (HxWxD)
nc6320 with WWAN
30.3 mm (at front) x 328.6 mm x 274.3 mm (1.2 (at front) x 12.9 x 10.8 inches)
with 15.0 inch display
2.77 kg (6.1 lb)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, 60 GB hard drive, 256 MB memory, and CD-ROM drive. Weight varies by configuration and components.
Electrical Specifications
Item
Specification
HP 65W Smart AC Adapter
Dimensions
10.6 cm x 4.7 cm x 2.8 cm (4.17 x 1.85 x 1.1 inches)
280 g (0.62 lb)
Input
100 to 240 VAC
Input Efficiency
83% min at 115 VAC
Input frequency range
47 to 63 Hz
Input AC current
  • 1.7 A at 90 VAC
  • 0.85 A at 180 VAC
Output
Output power 65W
65 Watts
DC output
18.5 Volts
Hold-up time
5 msec at 115 VAC input
Output current limit
  • < 11A
  • Over voltage protection: 29 Volt max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental Design
Operating temperature
32° degrees to 104° degrees F (0° degrees to 40° degrees C)
Non-operating (storage) temperature
-4° degrees to 149° degrees F (-20° degrees to 65° degrees C)
Altitude
0 to 10,000 feet (0 to 3,048 m)
Humidity
20% to 80%
Storage Humidity
10% to 90%
EMI and Safety Certifications
  • CE Mark: Full compliance with LVD and EMC directives;
  • Worldwide safety standards: IEC60950, EN60950, UL60950, Class1, SELV;
  • Agency approvals: C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE;
  • MTBF: Over 200,000 hours at 25° degrees C ambient condition.
Option Kit Contents
65W AC Adapter, power cable, warranty booklet
Optional HP 12-Cell Ultra-Capacity Battery
Dimensions (H x W x L)
3.33 cm x 15.25 cm x 26.88 cm (1.3 x 6.0 x 10.6 inches)
0.803 kg (1.77 lb)
Cells/Type
12-cell Lithium-Ion
Energy
Voltage
14.8 Volts
Watt-hour Capacity
95Wh
Amp-hour Capacity
6.45Ah
Temperature
Operating (Charging)
32° degrees to 113° degrees F (0° degrees to 45° degrees C)
Operating (Discharging)
14° degrees to 140° degrees F (–10° degrees to 60° degrees C)
Non-operating
–4° degrees to 140° degrees F (–20° degrees to 60° degrees C)
Battery Re-Charge Time
Smart Adapter
3 to 4 hours
System ON
4 to 5 hours (depending on system power consumption)
Fuel Gauge
When pressed, LEDs light indicating level of charge remaining on battery
Optional HP 8-Cell Extended Life Battery
2.5 cm x 10.0 cm x 22.0 cm (1.0 x 3.9 x 8.7 inches)
0.455 kg (1.00 lb)
Cells/Type
8-cell Lithium-Ion
Energy
Voltage
14.4 Volts
Watt-hour Capacity
52Wh
Amp-hour Capacity
3.6Ah
Temperature
Non-operating
System in OFF mode or Standby
3 hours
System ON
3 to 5 hours (depending on system power consumption)
HP Fast Charge Technology
Charges the battery up to 90% within 90 minutes when system is OFF
Fuel Gauge
52Wh Primary 6-Cell Battery
2.0 cm x 5.3 cm x 20.3 cm (0.8 x 2.1 x 8.0 inches)
0.335 kg (0.737 lb)
Cells/Type
6-cell Lithium-Ion
Energy
Voltage
10.8 Volts
Watt-hour Capacity
52Wh
Amp-hour Capacity
4.8Ah
Temperature
Non-operating
System in OFF Mode or Standby
2.5 hours
System ON
Charges the battery up to 90% within 1.5 hours when system is OFF
Environmental Specifications
Item
Specification
Stand-Alone Power Requirements
Normal Operating Voltage
18.5 Volts
Average Operating Power
12.5 Watts
Max Operating Power
< 65 Watts
Temperature
Operating
32° degrees to 95° degrees F (0° degrees to 35° degrees C) (not writing optical)
41° degrees to 95° degrees F (5° degrees to 35° degrees C) (writing optical)
Non-operating
-4° degrees to 140° degrees F (-20° degrees to 60° degrees C)
Relative Humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 101.6° degrees F (38.7° degrees C) maximum wet bulb temperature
Shock
Operating
125 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random Vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-50 to 10,000 feet (-15.24 to 3,048 m)
Non-operating
-50 to 40,000 feet (-15.24 to 12,192 m)
Audio Specifications
Item
Specification
Implementation
ADI1981HD High Definition CODEC
Volume Controls
Up, down, and mute buttons
Full Duplex
Yes
Sound Blaster Pro compatible
Yes
Microphone Jack
Stereo or mono
Headphone/Line Out Jack
Stereo
Audio Output Quality
Frequency Response
20 Hz – 20 kHz
Signal to Noise Ratio
> 85 dB
Total Harmonic Distortion
0.01%
Noise Floor
-110 dB
Play/Record Sampling Rate(s)
8 kHZ – 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Internal Speakers
Power Rating
2 Watts
Impedance
4 Ohms
Communications Specifications
Integrated Broadcom NetLink Gigabit Ethernet PCI Controller (BCM5788M)
Item
Specification
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (1000BASE-T; IEEE 802.3z and 802.3ab; IEEE 802.3 clauses 34-42)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
Power Management
  • ACPI compliant -- multiple power modes
  • Situation-sensitive features reduce power consumption
  • NIC Battery Saving Mode (enabled by default)
Performance Features
TCP/IP/UDP Checksum Offload (configurable)
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame);
  • Wake-on-LAN from off (Magic Packet only) PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
Interface
32-bit PCI, 33 MHz
NIC Device Driver Name
Drivers Available
Microsoft Windows XP
Microsoft Windows 2000
V.92 56K Data/Fax Modem
Item
Specification
Form Factor
MDC 1.5 Daughtercard
Power Management Support
APM Revision 1.2, ACPI
Approvals/ Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Data Mode Capabilities
  • V.92 data
  • V.8bis
  • V.80
  • V44, V.42bis, MNP5 (Compression)
  • V.42 (LAPM, MNP2-4) (Error Correction)
Optional symbol rates:
2800, 3429
Asymmetric Symbol rates
Synchronous primary channel data signaling rates:
3600, 31200
Automatic rate re-negotiation
  • V.34
  • V.32bis
  • V.32
  • V.23
  • V.22bis
  • V.22
  • V.21
  • Bell 212A
  • Bell 103J
Fax Mode Capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
Command Set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
HP ev2200 1xEV-DO Broadband Wireless Module
Item
Specification
Band and Power Class
  • 0 (North American Cellular) – Class III
  • 1 (North American PCS) – Class II
Wireless Protocol Standards
CDMA 1x Release 0/A; IS-95A, IS-95B, IS-2000
Wireless Parametric Standards
Meets or exceeds TIA/EIA IS-98-D
Interoperability
CDG 22 (TIA/EIA/IS-95-A)
CDG 53(TIA/EIA/IS-95-B)
C.S0031 (TIA/EIA/IS-2000)
CDG 64 (TIA/EIA/IS-2000)
C.S0032 (TIA/EIA/IS-866)
Frequency Band
Dual Band: 800 MHz (Cellular) and 1900 MHz (PCS)
Data Rates (Packet Mode)
IS-856 rates up to 2.4 Mbps
IS-2000 data rates up to 307.2 kbps
Maximum Output Power
24dBm (+/-1)
Power Consumption (maximum)
500mA
Power Consumption, Sleep Mode
1.7mA – 3.5mA
Power Management
  • USB selective suspend
  • CDMA slotted mode sleep and dormant modes
Antenna Type
High efficiency dual band antennae with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express MiniCard
0.35 oz (10 g)
Dimensions (Length x Width x Thickness)
51 mm x 30 mm x 4.5 mm (2.01 x 1.18 x 0.18 inches)
Voltage, Operating
3.3 Volts +/- 10%
Temperature, Operating (from TIA/EIA/IS-98-D)
-22° degrees to 140° degrees F (-30° degrees to 60° degrees C) (full RF performance)
-22° degrees to 167° degrees F (-30° degrees to 75° degrees C) (reduced RF performance)
Temperature, Nonoperating, 96 hours (from MIL-STD 202 Method 108)
-40° degrees to 185° degrees F (-40° degrees to 85° degrees C)
Humidity, Non-operating
85% relative humidity for 48 hours @ 185° degrees F (85° degrees C) (non-condensing)
Configuration Utilities
Verizon Wireless VZAccess Manager
LED Activity
LED Off – Radio Off
Solid LED On – Radio On
Broadcom 4311BG 802.11b/g WiFi Adapter
Item
Specification
Wireless LAN Standards
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant
Frequency Band
2.4 GHz
Data Rates
802.11b: 1, 2, 5.5, 11 Mbps
802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
Direct Sequence Spread Spectrum
DBPSK, DQPSK, CCK, OFDM
Security1
Supports 64-bit and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAPMSCHAPv2, LEAP, EAP-FAST, EAP-SIM
Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4)
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power (for CKK)2
17.5 dBm
Output Power
(for OFDM; power varies by data rate)2
15 dBm
Power Consumption
Transmit: 2.0 Watts (max)
Receive: 1.5 Watts (max)
Idle mode3: 390 mW (nominal)
Sleep mode: 20 mW (max)
Power Management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity4
54 Mbps: -72 dBm
11 Mbps: -88 dBm
1 Mbps: -97 dBm
Antenna type
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure
Range
802.11 b – Typical (@1 Mbps)
1200 feet – Outdoor Open Area
300 feet – Indoor, Office environment
802.11 g – Typical (@1 Mbps)
Form Factor
12 g (0.026 lb)
Dimensions
4.75 mm x 29.85 mm x 50.8 mm (0.19 x 1.2 x 2.0 inches)
Operating Voltage
3.3 Volts +/- 10%
Temperature
Operating
32° degrees to 176° degrees F (0° degrees to 80° degrees C)
Non-operating
-40° degrees to 176° degrees F (-40° degrees to 80° degrees C)
Humidity
Operating
10% to 90% (non-condensing)
Non-operating
5% to 95% (non-condensing)
Altitude
Operating
0 to 10,000 feet (3,048 m)
Non-operating
0 to 50,000 feet (15,240 m)
Configuration Utility5
Choice of Configuration Utility:
  • Microsoft Windows XP Wireless Network Connection Manager
  • Broadcom Wireless Configuration Utility (required for Cisco Compatible Extensions support)
LED Activity
LED Off – Radio OFF
Solid LED On – Radio ON
Note 1: Check latest software/driver release for updates on supported security features.
Note 2: Maximum output power may vary by country according to local regulations.
Note 3: In Power Save Polling mode.
Note 4: Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
Note 5: WLAN supplier's client utility is required for Cisco Compatible Extensions support. WLAN may also be compatible with certain third-party software supplicants.
Broadcom 4311AG 802.11a/b/g WiFi Adapter
Item
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
Frequency Band
2.4 GHz and 5 GHz
Data Rates
802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
Security1
Supports 64-bit and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAPMSCHAPv2, LEAP, EAP-FAST, EAP-SIM.
Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4).
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Roaming
17.5 dBm
Output Power
15 dBm
Power Consumption
Power Management
54 Mbps: -72 dBm
11 Mbps: -88 dBm
1 Mbps: -97 dBm
Antenna type
Range
802.11 a – Typical (@6 Mbps)
600 feet – Outdoor Open Area
150 feet – Indoor, Office environment
Form Factor
12 g (0.026 lb)
Dimensions
Operating Voltage
3.3 volts +/- 10%
Temperature
Operating
Non-operating
Humidity
Operating
Non-operating
Altitude
Operating
Non-operating
LED Activity
LED Off – Radio OFF
Intel PRO/Wireless 3945ABG 802.11a/b/g Network Connection
Item
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
Frequency Band
2.4 GHz and 5 GHz
Data Rates
Modulation
Security1
Sub-channels
Roaming
15 dBm
Output Power
15 dBm
Power Consumption
Transmit: 1.8 Watts (max)
Receive: 1.4 Watts (max)
Idle mode3: 150 mW (nominal)
Sleep mode: 30 mW (max)
Power Management
54 Mbps: -72 dBm
11 Mbps: -88 dBm
1 Mbps: -97 dBm
Antenna type
Range
Form Factor
6 g (0.013 lb)
Dimensions
Operating Voltage
3.3 volts +/- 10%
Temperature
Operating
Non-operating
Humidity
Operating
Non-operating
Altitude
Operating
Non-operating
  • Intel PROSet (required for Cisco Compatible Extensions support)
LED Activity
LED Off – Radio OFF
HP Integrated Module with Bluetooth Wireless Technology
Item
Specification
Bluetooth Specification
2.0 Compliant
Dimensions
26 mm x 14 mm x 5.7 mm (1.02 x 0.55 x 0.22 inches)
Frequency Band
2402 to 2480 MHz
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
3 Mbps data rate; throughput up to 2.17 Mbps
Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep < 1 mW
Antenna
Internally integrated within module
Range
Up 33 feet (10 m)
Electrical Interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
OS Support
Microsoft Windows XP Professional and Home
Bluetooth Software Supported
Broadcom Bluetooth for Windows
Microsoft Windows XP Bluetooth Software
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Temperature
Operating
-4° degrees to 158° degrees F (-20° degrees to 70° degrees C)
Non-operating
Humidity
Operating
10% to 90%
Non-operating
5% to 95%
Altitude
Operating
15,000 feet (4,572 m)
Non-operating
40,000 feet (12,192 m)
Bluetooth Profiles Supported
(with Bluetooth for Windows 4.0 software)
  • Serial Port Profile (SPP)1
  • Dial-Up Networking (DUN)1
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)1
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)1
  • Personal Area Networking Profile (PAN)1
  • Human Interface Device Profile (HID)1
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Note 1: Indicates the profile is also supported by Microsoft Windows XP SP2
Display Specifications
Item
Specification
15.0-Inch Color TFT SXGA+ Wide Viewing Angle Display
Active Area (W x H)
30.4 cm x 22.8 cm (12.0 x 9.0 inches)
Diagonal Size
38.0 cm (15.0 inch)
Surface Treatment
Anti-glare
Number of Colors
Up to 16M
Contrast Ratio
300:1 (typical)
Refresh Rate
60 Hz
Brightness
170 nit (typical)
Pixel Resolution
Pitch
0.217 mm
Format
1400 x 1050
Configuration
RGB Stripe
Backlight
CCFL
PPI
117
Viewing Angle
±60° degrees Horizontal, +40° degrees / -45° degrees Vertical (typical)
15.0-Inch Color TFT XGA Display
Active Area (W x H)
Diagonal Size
38.0 cm (15.0 inch)
Surface Treatment
Anti-glare
Number of Colors
Up to 16M
Contrast Ratio
300:1 (typical)
Refresh Rate
60 Hz
Brightness
150 nit (typical)
Pixel Resolution
Pitch
0.296 mm
Format
1024 x 768
Configuration
RGB Stripe
Backlight
CCFL
PPI
86
Viewing Angle
±45° degrees Horizontal, ±25° degrees Vertical (typical)
Hard Drive Specifications
100 GB 5400 rpm SATA
Item
Specification
Drive Weight
101 g (0.22 lb)
Capacity
100 GB
Height
9.5 mm (0.37 inch)
Width
70 mm (2.75 inch)
Interface
ATA-7 / SATA 1.0a
Transfer Rate
Synchronous (maximum)
100 MB/s (Drive Capability)
Seek Time (typical reads, including settling)
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
195,371,568
Operating Temperature
41° degrees to 140° degrees F (5° degrees to 60° degrees C) [case temp]
Features
ATA Security
80 GB 5400 rpm SATA
Item
Specification
Drive Weight
101 g (0.22 lb)
Capacity
80 GB
Height
9.5 mm (0.37 inch)
Width
70 mm (2.75 inch)
Interface
ATA-7 / SATA 1.0a
Transfer Rate
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
156,301,488
Features
ATA Security
60 GB 5400 rpm SATA
Item
Specification
Drive Weight
101 g (0.22 lb)
Capacity
60 GB
Height
9.5 mm (0.37 inch)
Width
70 mm (2.75 inch)
Interface
ATA-7 / SATA 1.0a
Transfer Rate
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
117,231,408
Features
ATA Security
40 GB 5400 rpm SATA
Item
Specification
Drive Weight
101 g (0.22 lb)
Capacity
40 GB
Height
9.5 mm (0.37 inch)
Width
70 mm (2.75 inch)
Interface
ATA-7 / SATA 1.0a
Transfer Rate
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
78,165,360
Features
ATA Security
Removable Storage Drive Specifications
DVD-ROM Drive
Item
Specification
Access Times
Random
< 116 ms CD
< 125 ms DVD
Max Data Transfer Rate
24X CD-ROM
3,600 KB/s
8X-DVD
10,800 KB/s
Transfer Mode
Multiword DMA Mode 2
Interface
EIDE
Supported Media (read)
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVDROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW
Supported Media (write)
None
Max Media Capacity (read)
4.7 GB
Transport
Tray Loading
DVD/CD-RW Combo Drive
Item
Specification
Access Times
Random
< 110 ms CD
< 130 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
24X CD-RW
3,600 KB/s
Transfer Mode
Interface
EIDE
CD-R, CD-RW
8.5 GB
Max Media Capacity (write)
700 MB
Transport
Tray loading
LightScribe DVD+/-RW Drive with Double Layer
Item
Specification
Access Times
Random
< 175 ms CD
< 230 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
10X CD-RW
1,500 KB/s
8X DVD+R
10,800 KB/s
4X DVD+RW
5,400 KB/s
8X DVD-R
10,800 KB/s
4X DVD-RW
5,400 KB/s
2.4X DVD+R(9)
2,700 KB/s
Transfer Mode
Interface
EIDE
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, LightScribe
8.5 GB
8.5 GB
Transport
Tray Loading
DVD+/-RW SuperMulti Drive with Double Layer
Item
Specification
Access Times
Random
< 175 ms CD
< 230 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
10X CD-RW
1,500 KB/s
8X DVD+R
10,800 KB/s
4X DVD+RW
5,400 KB/s
8X DVD-R
10,800 KB/s
4X DVD-RW
5,400 KB/s
2.4X DVD+R(9)
2,700 KB/s
5X DVD-RAM
6,750 KB/s
Transfer Mode
Multiword DMA Mode
Interface
EIDE
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVDROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM
8.5 GB
8.5 GB
Transport
Tray Loading
HP Biometric Fingerprint Sensor
Item
Specification
Mobile Voltage Operation
3.0 Volts – 3.6 Volts Single Supply
32° degrees – 158° degrees F (0° degrees – 70° degrees C)
Current Consumption @ 3.3V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced Power Management
High-Rate Image Capture
Up to 240 image frames /sec
ESD Resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection Matrix
  • 192 x 16 Pixels
  • 9.7mm x 0.81mm
  • 500 ppi High-Resolution Images
Industry Standard Certifications
Certified
UL
Yes
CSA
Yes
FCC Compliance
Yes
Energy Star Compliant
Yes
ICES
Yes
GS
Yes
Australia / NZ A-Tick Compliance
Yes
CCC
Yes
Japan VCCI Compliance
Yes
MIC
Yes
BSMI
Yes
CE Marking Compliance
Yes
BNCI or BELUS
Yes
CIT
Yes
GOST
Yes
Saudi Arabian Compliance (ICCP)
Yes
SABS
Yes
UKRSERTCOMPUTER
Yes
