HP Deskjet D2320, D2330, D2345, and D2360 Printers - Print Cartridge Problem Message
Issue
After a print cartridge is installed, the power light begins to blink. The printer will not print. A print cartridge error message displays on your computer screen.
Solution
Work through the sections below in order. When the power light stops blinking, you have solved the problem.
    Figure : Printer control panel
  1. Printer power button and light
The graphics used below may vary slightly from your printer model but the functions remain the same.
Step 1: Remove, inspect, and reseat the cartridges
The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the cartridge to release it.
    Figure : Removing the tri-color cartridge
  4. Slide the cartridge out and inspect it:
    Do not touch the copper electrical contacts or the ink nozzles.
      Figure : Electrical contacts and nozzles
    1. Copper electrical contacts
    2. Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed.
      Do not attempt to remove the copper electrical strip!
      Figure : Removing the clear nozzle protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figure : Sliding the cartridge into the carriage
    Figure : Pushing the cartridge into place
Step 2: Clean the cartridge contacts
  1. Gather the following items to clean the ink cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the ink cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the ink cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the ink cartridge on during cleaning.
  2. Open the ink cartridge access door and wait until the carriage is idle and silent.
  3. Disconnect the power cord from the back of the printer.
  4. Remove the ink cartridge and place it on a piece of paper with the nozzle plate facing up.
    Do not leave the ink cartridges outside of the printer for more than 30 minutes. If the ink cartridge is outside of the printer for too long, the ink can dry and clog the nozzles.
  5. Dip a clean foam-rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it.
  6. Clean only the copper-colored contacts
    1. Copper-colored contacts
    2. Ink nozzles (do not clean)
  7. Repeat these steps for the other ink cartridge.
  8. Lightly moisten another cotton swab with distilled water, and then squeeze any excess water from the swab.
  9. Use the swab to clean the electrical contacts in the carriage, located inside the printer on the carriage slots.
    Image: The electrical contacts in the ink cartridge slots
  10. Wait 10 minutes to allow the ink cartridge and carriage electrical contacts to dry.
  11. Reinstall the ink cartridges.
  12. Close the ink cartridge access door.
  13. Reconnect the power cord to the back of the printer.
  14. Press the Power button to turn on the printer.
  15. Try to print a page.
  16. If you are still unable to print, repeat these steps to clean and reseat the ink cartridges. Multiple cleanings might be necessary to restore printing.
Step 3: Repeat reseating and cleaning steps
If the problem is not solved, repeat the reseating and cleaning procedures above.
Step 4: Contact HP
If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now. Go to Ink Cartridge and Printhead Limited Warrantyto see if the cartridge is covered under warranty.
Step 5: Print in backup mode
If you do not have a replacement cartridge, you can still print in ink backup mode. Simply remove the problem cartridge, and print with the remaining cartridge.
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product prints slowly and the colors in the printouts might differ.
