HP Scanjet 8300, 8350, and 8390 Scanners - Product Specifications
Figure : HP Scanjet 8300 series scanner
Model number
Product Name
Model Number
HP Scanjet 8300 Professional Image Scanner
L1960A
HP Scanjet 8300 Digital Flatbed Scanner
L1963A
HP Scanjet 8350 Document Flatbed Scanner
L1961A
HP Scanjet 8390 Document Flatbed Scanner
L1962A
Serial number location
The serial number is located on the bottom of the unit.
Scanner specifications
Name
Scanner type
Flatbed with transparent materials adapter (TMA)
Size
  • 8300: 625 x 415 x 130 mm (24.61 x 16.34 x 5.12 inches)
  • 8350/8390: 625 x 415 x 265 mm (24.61 x 16.34 x 10.43 inches)
  • 8300: 8.9 kilograms (19.58 pounds)
  • 8350/8390: 15 kilograms (33 pounds)
Scanning element
Charged-coupled device
Interface
USB 2.0 Hi-Speed
Optical resolution
4800 x 4800 dpi hardware
AC power
100 to 240 volts, 50/60 Hz, 1.5 amps
Power consumption and regulatory information
For power consumption data, see the regulatory_supplement.htm file on the HP Photosmart Software CD.
Energy efficiency
The HP scanner is ENERGY STAR compliant. As an ENERGY STAR partner, the Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency.
Transparent materials adapter (TMA) specifications
Name
Media types
  • Negative strips: Three 35 mm strips each containing six frames
  • 35 mm slides: Eight slides
  • Medium (120/220) film: Up to 6 x 9 cm (2.36 x 3.54 inch) frame
  • Large format: One 1.57 x 1.97 mm (4 x 5 inch) frame
Media capacity
Slide: 1.05 to 3.26 mm (0.04 to 0.13 inch) thick and 49.8 to 50.8 mm (1.96 to 2 inch) on any side
Power requirements
24 volts direct current, 700 mA
Automatic document feeder (ADF) specifications
Name
Size
625 x 415 x 160 mm (24.61 x 16.34 x 6.30 inches)
Weight with scanner
Paper tray capacity
100 sheets of 83 g/m2 (18.2 pound bond)
Maximum paper size
210 x 355.6 mm (8.5 x 14 inches)
Minimum paper size
148 x 148 mm (5.8 x 5.8 inches)
Maximum paper weight
105 g/m2 (28 pound)
Power requirements
  • 5 volts direct current, 830 mA
  • 18 volts direct current, 310 mA
  • 32 volts direct current, 1260 mA
Environmental specifications
Operating conditions
The operating conditions apply when using the scanner and TMA.
Name
Temperature
10 to 35 degrees C (50 to 95 degrees F)
Relative humidity
15 to 80 percent non-condensing
Storage conditions
Name
Temperature
-40 to 60 degrees C (-40 to 140 degrees F)
Relative humidity
Up to 90 percent non-condensing at 0 to 60 degrees C (32 to 140 degrees F)
Minimum system requirements
Windows
  • Computer with Intel Pentium II 233 MHz or equivalent Celeron processor
  • Universal Serial Bus (USB) port
  • Windows 98, 98 SE, Me, XP Home or Professional, or 2000 Professional Edition
  • 64 MB RAM for Windows 98, 98 SE, and Me; 128 MB RAM for Windows 2000 and XP
  • 500 MB free hard disk space required to install
  • Internet Explorer 5.01 Service Pack 2 or later version
  • CD-ROM drive
  • SVGA monitor (800 x 600 pixels, 16-bit color)
Macintosh
  • Mac OS v 10.2.8, 10.3, 10.4
  • 128 MB RAM (256 MB recommended)
  • 250 MB available disk space
  • 800 x 600 SVGA monitor
  • CD-ROM drive
  • USB port
Model
Asia Pacific
Americas
Europe/Middle East/Africa
8300
1 year
1 year
1 year
8350
1 year
1 year
1 year
8390
1 year
1 year
3 years
