Printer Specifications for HP Officejet 6300 All-in-One Printer Series
This document outlines the product specifications for the HP Officejet 6300 series all-in-ones.
HP Officejet All-in-One models
Printer model
Part number
Region
HP Officejet 6301
Q8073A
North America
HP Officejet 6304
Q8067C
Middle East and Africa
HP Officejet 6305
Q8064A
United States, Latin America, and Asia Pacific
Q8064B
Europe
HP Officejet 6307
Q8065A
Europe
HP Officejet 6308
Q8072D
China and India
HP Officejet 6310
Q8061A
North America, Latin America, and Asia Pacific
Q8061B
Europe
Q8077C
Japan
HP Officejet 6310v
Q8063A
North America
HP Officejet 6310xi
Q8062A
North America
HP Officejet 6313
Q8061C
HP Officejet 6315
Q8066B
Europe
HP Officejet 6318
Q8069D
China and India
Component
Minimum system requirements
Windows 2000, Windows XP, Windows Vista, and Windows 7
Processor
Windows 2000 and Windows XP: Any Intel Pentium II, Celeron, or compatible processor (Pentium III or higher recommended)
Windows Vista and Windows 7: A modern 800 MHz 32-bit (x86) or 64-bit (x64) processor (1 GHz or higher recommended)
RAM
Windows 2000 and Windows XP: Typical installation: 128 MB RAM (256 MB RAM recommended)
Windows Vista and Windows 7: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and Windows XP: Typical installation: 795 MB (1 GB Japan only) free hard disk space, plus an additional 50 MB free for full color scanning
Windows Vista and Windows 7: Typical installation: 920 MB free hard disk space, plus an additional 50 MB free for full color scanning
Connectivity
USB 2.0 full speed, front and back ports
PictBridge: Using front camera port
Bluetooth: Using optional HP Bluetooth wireless printer adapter (print functionality only)
Ethernet: CAT-5, RJ-45 wired network connection
Browser
Typical installation: Microsoft Internet Explorer 6 or higher
Macintosh system requirements
Component
Macintosh
OS 10.3 and OS 10.4
Processor
G3 or greater
RAM
128 MB
Free disk space
500 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
Connectivity
PictBridge: using front camera port
Bluetooth: using optional HP Bluetooth printing adapter (print functionality only)
Printing specifications
General
Category
Specification
Resolution
1200 x 1200 dots per inch (dpi) black; 4800 optimized dpi color or 6 ink
Method
Drop-on-demand thermal inkjet
Language
PCL3
Print speed (varies by model)
up to 30 pages per minute (ppm) black; up to 24 ppm color
Duty cycle
3000 pages per month
Print speeds
Mode
Type
Speed (ppm)1
Speed (seconds) 4 x 6 inch borderless photo1
Maximum dpi
Black and Color
up to 0.4
as fast as 140
Best
Black and Color
up to 2.3
as fast as 74
Normal
Black
up to 8.5
as fast as 54
Color
up to 5.3
as fast as 54
Fast Normal
Black
up to 11
as fast as 30
Color
up to 8
as fast as 30
Fast Draft
Black
up to 30
as fast as 30
Color
up to 24
as fast as 30
1Print speeds vary according to the complexity of the document.
Copying specifications
  • Digital image processing
  • Up to 100 copies from original (varies by model)
  • Digital zoom (varies by model): from 25 to 400%
  • Fit to page, pre-scan
Mode
Type
Speed (ppm)1
Scan resolution (dpi)1
Best
Black
up to 0.8
up to 600 x 1200
Color
up to 0.8
up to 600 x 1200
Normal
Black
up to 8.5
up to 300 x 300
Color
up to 5.1
up to 300 x 300
Fast
Black
up to 30
up to 300 x 300
Color
up to 24
up to 300 x 300
1Copy speeds vary according to the complexity of the document.
1Maximum at 400% scaling.
Scanning specifications
  • Image editor included
  • Integrated Optical Character Recognition (OCR) software automatically converts scanned text to editable text
  • Scan speeds vary according to the complexity of the document
  • TWAIN compliant interface
  • Resolution: 2400 x 4800 dpi optical; up to 19,200 dpi enhanced
  • Color: 16-bit per RGB; 48-bit total
  • Maximum scan size from the glass: 216 x 297 mm (8.5 x 11.7 inches)
Faxing specifications
  • Walk-up black and white or color fax capability.
  • Up to 110 speed dials (varies by model).
  • Up to 120-page memory (varies by model, based on ITU-T Test Image #1 at standard resolution). More complicated pages or higher resolution take longer and use more memory.
  • Manual fax send and receive.
  • Automatic busy redial up to five times (varies by model).
  • Automatic no-answer redial one time (varies by model).
  • Confirmation and activity reports.
  • CCITT/ITU Group 3 fax with Error Correction Mode (ECM).
  • 33.6 Kbps transmission speed.
  • 3 seconds per page speed at 33.6 Kbps (based on ITU-T Test Image #1 at standard resolution). More complicated pages or higher resolution take longer and use more memory.
  • Ring detect with automatic fax/answering machine switching.
Color
Photo (dpi)
Very fine (dpi)
Fine (dpi)
Standard (dpi)
Black
196 x 203 (8-bit grayscale)
300 x 300
196 x 203
196 x 98
Color
200 x 200
200 x 200
200 x 200
200 x 200
Memory card specifications
General recommendations
  • Maximum recommended number of files on a memory card: 1000
  • Maximum recommended individual file size: 12 megapixel or 8 MB
  • Maximum recommended memory card size: 1 GB (solid state only)
Approaching any of the recommended maximums on a memory card might cause the performance of the HP All-in-One to be slower than expected.
Supported memory card types
  • CompactFlash
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick Pro
  • Secure Digital (SD)
    SDHC cards are not supported.
  • MultiMediaCard (MMC)
  • xD-Picture Card
Other memory cards, including Memory Stick Magic Gate Duo, Memory Stick Duo, and Secure Multimedia Card, are supported with the use of an adapter.
Paper specifications
Paper tray capacities
Type
Paper weight
Input tray1
Output tray2
Document feeder tray
Plain paper
60 to 90 gsm (16 to 24 pounds)
up to 100 (20 pound paper)
up to 50 (20 pound paper)
up to 35
Legal paper
75 to 90 gsm (20 to 24 pounds)
up to 20
Cards
up to 200 gsm (110 pounds)
up to 40
up to 10
N/A
Envelopes
up to 15
up to 10
N/A
Transparency film
N/A
up to 25
up to 25
N/A
Labels
N/A
up to 20
up to 20
N/A
102 x 152 mm (4 x 6 inches) photo paper
up to 236 gsm (145 pounds)
up to 30
up to 10
N/A
216 x 280 mm (8.5 x 11 inches) photo paper
N/A
up to 40
up to 20
N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Paper sizes
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm (8.3 x 11.7 inches)
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. 9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
Premium photo paper
Cards
A6: 105 x 148.5 mm (4.1 x 5.8 inches)
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels
Custom
102 x 152 mm to 216 x 356 mm (4 x 6 inches to 8.5 x 14 inches)
Print margin specifications
Paper size
Top (leading edge)
Bottom (trailing edge)
Left and Right margins
US Letter
US Legal
US Executive
3 mm (0.12 inches)
3 mm (0.12 inches)
7.1 mm (0.28 inches)
ISO A4
ISO A5
JIS B5
3 mm (0.12 inches)
3 mm (0.12 inches)
Envelopes
3 mm (0.12 inches)
3 mm (0.12 inches)
7.1 mm (0.28 inch)
Cards
3 mm (0.12 inches)
3 mm (0.12 inches)
7.1 mm (0.28 inch)
Physical specifications
Dimension
Measure
Height
236 mm (9.29 inches)
Width
456 mm (17.95 inches)
Depth
326 mm (12.83 inches)
7.66 kilograms (16.9 pounds)
Power specifications
Category
Specification
Power consumption
60 watt maximum
Idle state power consumption
8.5 watt
Input voltage
100 to 240 volts, alternating current
Input current
1 A
Input frequency
50 to 60 Hz, grounded
Output voltage
16 to 32 volts, direct current
Output current
600 to 900 mA
Environmental specifications
In the presence of high electromagnetic fields it is possible that the output from the HP Officejet might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Recommended operating conditions
Specification
Temperature
15 to 32 degrees C (59 to 90 degrees F)
Humidity
15 to 85 percent relative humidity non-condensing
Maximum operating conditions
Specification
Temperature
5 to 40 degrees C (41 to 104 degrees F)
Humidity
Storage conditions
Specification
Temperature
-40 to 60 degrees C (-40 to 140 degrees F)
Humidity
Country: Flag Thailand
