    We are upgrading our website
HP Designjet 4500 Stacker - Installing/Uninstalling Stacker on Printer
Installing the stacker
  1. Connect the cables between the stacker and the printer.
    Figure : Connecting cables
  2. Turn on the stacker.
  3. Select the (roll) icon on the printer's front panel, then Accessories, Stacker, Install stacker. The front panel will prompt to attach the stacker to the printer.
  4. There are two latches on the stacker that engage with the printer deflectors. To attach the stacker to the printer, attach first one side and then the other (because less force is required that way).
Some warm-up time is necessary, especially when the stacker has just been switched on.
The stacker operates on cut sheets of paper. When it is switched on, the cutter is automatically enabled. It cannot work if the cutter is turned Off or if the printing material cannot be cut (canvas, for example).
Uninstalling the stacker
  1. To uninstall the stacker, select the (roll) icon on the printer's front panel, then Accessories, Stacker, Uninstall stacker.
  2. The front panel will then prompt to detach the stacker from the printer. Pull the stacker from one side to detach it on that side, then detach the other side.
  3. Disconnect the stacker cables.
    Figure : Disconnecting the stacker
Country: Flag Thailand
