Opening the PC Case in HP Pavilion a1000, t3000 Series Desktop PCs
This document only pertains to HP desktop PCs with the following PC case:
Before you begin
  • Turn off the PC, disconnect all cables and transfer the PC to a clear, flat, stable work surface over a non-carpeted floor. Be sure to disconnect the modem cable before disconnecting the power cord.
  • HP strongly recommends the use of an anti-static wrist strap and a conductive foam pad when working on the PC.
  warning:
Video overview
View the following video before using the steps in this document.
Step 1: Removing the right side panel
To access most components, remove the right side panel.
  warning:
The left side panel does not need to be removed to service any part of this HP Pavilion Desktop PC.
Step 1. With all cables disconnected from the PC, detach the thumb screw that connects the right side panel to the rear of the PC case.
Step 2. Lay the PC case on its side, grasp the handle on the panel, and pull toward the back of the PC.
Step 3. Then lift the panel off the PC case.
Step 2: Replacing the right side panel
The right side panel has eight interior tabs.
These fit into corresponding slots on the PC case.
There are also five tabs on the front leading edge that fit into a lip on the PC case.
Step 1. Gently lay the PC on its side.
Step 2. Align the tabs on the panel into the slots in the PC case.
Step 3. From the back of the PC, push the panel forward until the front leading edge is secured.
Step 4. Resecure the thumb screw to secure the panel to the PC Case.
