HP Compaq dx2060 Microtower PC - Specifications
System Specifications
Feature
Enter para text
Intel Celeron D Processors:
  • Intel Celeron D 326 Processor (2.53-GHz, 256K L2 cache, 533-MHz FSB)
  • Intel Celeron D 331 Processor (2.66-GHz, 256KB L2 cache, 533-MHz FSB)
  • Intel Celeron D 336 Processor (2.80-GHz, 256KB L2 cache, 533-MHz FSB)
  • Intel Celeron D 341 Processor (2.93-GHz, 256KB L2 cache, 533-MHz FSB)
  • Intel Celeron D 346 Processor (3.06-GHz, 256KB L2 cache, 533-MHz FSB)
  • Intel Celeron D 351 Processor (3.20-GHz, 256KB L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors:
  • 506- 2.66-GHz, 1-MB L2 cache, 533-MHz FSB
  • 516- 2.93-GHz, 1-MB L2 cache, 533-MHz FSB
  • 519K – 3.06-GHz, 1-MB L2 cache, 533-MHz FSB
Intel Pentium 4 Processors supporting Hyper-Threading Technology:
  • 521- 2.80-GHz, 1-MB L2 cache, 800-MHz FSB
  • 531- 3.0-GHz, 1-MB L2 cache, 800-MHz FSB
  • 541- 3.20-GHz, 1-MB L2 cache, 800-MHz FSB
  • 551- 3.40-GHz, 1-MB L2 cache, 800-MHz FSB
  • 630- 3.00-GHz, 2-MB L2 cache, 800-MHz FSB
  • 640- 3.20-GHz, 2-MB L2 cache, 800-MHz FSB
  • 650- 3.40-GHz, 2-MB L2 cache, 800-MHz FSB
  • Intel915GV/915G
  • Intel ICH6
Chassis
uATX microtower
System Memory
Single Channel Configurations
  • 512-MB DDR2 SDRAM PC2-4200 (533-MHz) Non-ECC ( 2 x 256-MB)
  • 1-GB DDR2 SDRAM PC2-4200 (533-MHz) Non-ECC ( 2 x 512-MB)
  • 2-GB DDR SDRAM PC2-4200 (533-MHz) Non-ECC ( 2 x 1-GB)
For best performance, memory speeds and sizes should not be mixed.
Dual Channel Configurations
Physical Specifications
Feature
Specification
Chassis Dimensions (H x W x D)
368x175 x400mm (14.49 x 6.89 x 15.75 in)
Package Dimensions (L x W x H)
555 x 501 x 402 mm (21.85 x 19.72 x 15.83 in)
System Weight
8.4 kg (18.48 lb)
Shipping Weight
12.1 kg (26.62 lb)
Electrical Specifications
Feature
Specification
Power Supply
  • ATX Power Supply – Passive PFC at 230V only/non-PFC with a 115v/230V line switch
  • Passive Power Factor Correction (PFC) – with voltage set to 230V
  • 50-60 Hz rated line frequency
  • 230 watt maximum rated power
Power Conservation 'Energy Saver'
  • Energy Star Compliant
  • APM 1.2 support
  • Screen blanking
  • Hard drive 'Idle' mode
  • System Idle mode
  • CCEC - China only (<3 w in S5 - power off)
  • <4 watt power consumption in ES mode - suspend to RAM (S3) (instantly available PC)
  • Processor/Cache memory power-down (S3)
Environmental Specifications
Feature
Specification
Temperature Range
Operating Temperature
  • 10° to 35° C (50° to 95° F)
Non-operating Temperature
  • -30° to 60° C (022° to 140° F)
Relative Humidity
Operating Humidity
  • 10% to 90% (non condensing at ambient)
Non-operating Humidity
  • 5% to 95% (non condensing at ambient)
Maximum Altitude (Unpressurized)
Operating
  • 2500 m (8,000 ft)
Non-operating
  • 9000 m (30,000 ft)
Operating temperature is de-rated 1.0 deg C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10 deg C/Hr. The upper limit may be limited by the type and number of options installed.
Motherboard Specifications
Feature
Specification
Processor
  • Socket T; LGA 775
  • Support single Intel Pentium 4/Celeron 800/533MHz FSB processors
PWM
  • ON 3 phase power solution
  • Meet Intel FMB 04A spec
  • Intel 915GV/915G
  • Intel ICH6
Super I/O
  • ITE IT8712
Front Side Bus Frequency
  • 533/800-MHz
Memory
  • 2 x DIMM sockets
  • Support single and dual channel
  • PC2-4200 DDR2 SDRAM
Clock Generator
  • IDT CK410/ICS954119
Integrated Graphics
  • Intel GMA900 (integrated on the 915GV/915G chipset)
Audio
  • Realtek ALC653 2 channel audio
  • 3D audio compliant with AC'97 rev. 2.3
LAN
  • Realtek 8100C 10/100 LAN
IDE
  • Support all PIO modes
  • 1xIDE port support up to 2 Optical devices
  • Support Ultra ATA 33/66/100
Expansion Slots
  • 2 x PCI 2.3 slots
  • 1 - PCIex1 slot
  • 1 – PCIex16 slot (dx2180 only)
BIOS
  • 4Mbit flash EEPROM
  • Award BIOS, PnP, ACPI, SMBIOS 2.4, Boot Block, DMI
Manageability
  • WfM 2.0, DMI 2.0, SMBus
Industrial Standard
  • PCI 2.3 compliant
  • USB 2.0
Rear Side I/O Ports
  • 1 x PS/2 keyboard port
  • 1 x PS/2 mouse port
  • 4 x USB 2.0 ports
  • 1 x RJ-45 10/100 port
  • 1 x serial port
  • 1 x parallel port
  • 1 x DB 15 pin analog VGA port
  • 3 x audio ports
On Board I/O Interfaces
  • 1 x ATX power connector
  • 1x+12V power connector
  • 1 x Floppy connector
  • 1 x Front panel connector, Switch, LED (Power/HDD)
  • 2 x Fan headers for CPU, chassis, with voltage/fan speed control
  • 1 x ATAPI headers-CD IN
  • 1 x header to support 2 USB 2.0 ports at front side
  • 1 x IDE connector (Optical drive)
  • 2 x SATA connectors
  • 1 x audio header ( mic in/audio out)
Board Size
  • uATX form factor, PCB size: 9.6 x 9.0 in
  • 4-layer PCB with green color
Additional Feature
  • Keyboard/mouse/USB/LAN wake up
  • Support S1, S3, S4 and S5
  • ACPI status
  • hardware monitor capability
  • CPU fan speed control
Hard Drive Specifications
40-GB 7200 rpm Serial ATA Hard Drive
Feature
Specification
Capacity
40,020,664,320 bytes
Dimensions (H x W)
1.0 x 4.0 in (2.5 x 10.2 cm)
Interface
Serial ATA
Synchronous Transfer Rate (Maximum)
1.5 Gb/s
Buffer
2 MB
Seek Time (typical reads, including settling)
Single Track
1.0 ms
Full-Stroke
8.5 ms
Average
18 ms
Rotational Speed
7200 rpm
Logical Blocks
78,165,360
32° to 140° F (0° to 60° C)
80-GB* 7200 rpm Serial ATA Hard Drive
Feature
Specification
Capacity
80,026,361,856 bytes
Dimensions (H x W)
Interface
Serial ATA
1.5 Gb/s
Buffer
8 MB
Single Track
1.0 ms
Full-Stroke
8.5 ms
Average
18 ms
Rotational Speed
7200 rpm
Logical Blocks
156,301,488
160-GB* 7200 rpm Serial ATA Hard Drive
Feature
Specification
Capacity
160,041,885,696 bytes
Dimensions (H x W)
Interface
Serial ATA
1.5 Gb/s
Buffer
8 MB
Single Track
1.0 ms
Full-Stroke
8.5 ms
Average
18 ms
Rotational Speed
7200 rpm
Logical Blocks
312,581,808
250-GB* 7200 rpm Serial ATA Hard Drive
Feature
Specification
Capacity
250,059,350,016 bytes
Dimensions (H x W)
Interface
Serial ATA
1.5 Gb/s
Buffer
8 MB
Single Track
1.0 ms
Full-Stroke
< 9.0 ms
Average
< or = 17 ms
Rotational Speed
7200 rpm
Logical Blocks
488,397,168
41° to 131° F (5° to 55° C)
Although this drive is rated for a 3.0-Gb/s transfer rate, the Serial ATA interfaces in The HP Compaq dx2060/dx2180 Microtower support data transfer rates up to 1.5 Gb/s.
Optical Drive Specifications
48X Max CD-ROM Drive
Interface Type
ATAPI
Dimensions - (H x W x D maximum)
4.3 x 15.0 x 20.3 cm (1.7 x 5.9 x 6.0 inches)
1200 g (2.6 pounds)
Disc Loading Mechanism
Half-height, tray load
Disc Diameter
12 cm, 8 cm
Disc Thickness
1.2 mm (0.05 inch)
Track Pitch
1.6 µm
Read Only Disc formats
CD-ROM Mode 1, CD-ROM XA (Mode 2, Form 1 and 2), CD Digital Audio, CD-EXTRA, CD-I (Mode 2, Form 1 and 2) and CD-I Ready, CD-Text, CD-Bridge, Photo CD (Single and Multi Session), Video CD, CD-R and CD-RW Multi-Session
Disc Formats Written
None
Disc Capacity
180 MB (8 cm); 540 MB (12 cm); 650 MB (12 cm); 700 MB (12 cm)
Block Size (bytes)
Mode 1 - 2,048, 2,352 bytes
Mode 2 - 1, 2,048, 2,328, 2,336, 2,340, 2,353 bytes
Mode 2 - 2, 2,328, 2,336, 2,340, 2,352 bytes
CD-DA - 2,352, 2,368 bytes
Access Times (typical)
Random: less than 125 ms
Full Stroke seek: less than 210
Data Transfer Rates
Variable (Audio CD) - 1,800 to 3,600 KB/s (24X) Max Variable (CD-ROM, CD-R) - 2,400 to 7,200 KB/s (48X) Max
Data Buffer
2 MB
Start-up Time (single)
less than 7 seconds typical, less than 30 seconds with multi-session
Audio Output Level
Line-out-0.7 V at 47 Kohm
Environmental (all conditions non-condensing)
Temperature (operating): 5 degrees to 50 degrees C (41 degrees to 122 degrees F)
Relative Humidity (operating): 10 percent to 90 percent
Operating Systems supported
Microsoft Windows 2000, Windows XP Professional, Windows XP Home
Kit Contents
CD-ROM drive, installation guide, warranty card
48X/32X/48X CD-RW Drive
Orientation
Either horizontal or vertical
Interface Type
ATAPI IDE
Dimensions - External, excluding Bezel
203 x 149.5 x 43.5 mm (7.99 x 5.88 x 1.71 inches) external, excluding bezel
1.2 kg (2.6 pounds)
Disc Diameter
12 cm, 8 cm
Disc Thickness
1.2 mm (0.05 inch)
Track Pitch
1.6 µm (CD), 0.74 µm (DVD
Disc Center Hole Diameter
15 mm (0.6 inch)
Reference Scanning Velocity
1.2 m/s
Recording/Playing Time
80 minutes with CD-R media
CD-ROM-Mode 1; CD-ROMCD-ROM-Mode 1; CD-ROM XA-Mode 2 (forms 1 and 2); CD digital audio; CD Extra; CD-I-Mode 2 (forms 1 and 2) and CD-I-Ready; Photo CD (single and multi-session); video CD
Disc Capacity
185 MB (Mode 2, 8cm); 540 MB (Mode 1, 12 cm); 650 MB (Mode 2, 12 cm); 700 MB (Mode 2, 12 cm
Block Size (bytes)
Mode 1-2,048 and 2,352 bytes; mode 2, form 1-2,048; 2,328; 2,336; 2,340 and 2,352 bytes; mode 2, form 2-2,328; 2,336; 2,340 and 2,352 bytes; CD-DA-2,352 and 2,368 bytes
Writable Disc Parameters
Disc Type
CD-R and CD-RW
Write Methods
Disc at Once, Track at Once, Session at Once, Variable Packet, Fixed Packet
Format and Modes Supported
CD-ROM (mode 1); CD-ROM XA (mode 2, forms 1 and 2); CD digital audio, CD-I (mode 2, forms 1 and 2); video CD
Capacity
185 MB (Mode 2, 8cm); 540 MB (Mode 1, 12 cm); 650 MB (Mode 2, 12 cm); 700 MB (Mode 2, 12 cm)
Block Size
Mode 1 - 2,048 bytes; mode 2, form 1 - 2,048 and 2,352 bytes; mode 2, form 2 - 2,352 bytes; CD-DA - 2,352 bytes
Random: less than 120 ms
Full Stroke: 200 ms
Maximum Data Transfer Rates
CD-RW read: 7200 KB/s (32X) Max
CD-RW write: 4800 KB/s (32X) Max
CD-ROM, CD-R read: 7200 KB/s (48X) Max
Data Transfer Modes
ATA PIO mode 4 (16.7MB/s); ATA multi-word DMA mode 2 (16.7 MB/s); ATA UltraDMA mode 0 (16.7 MB/s) ;ATA UltraDMA mode 1 (24 MB/s) ; ATA UltraDMA mode 2 (33 MB/s) - default.
Power
Source: Four-pin, DC power receptacle
DC Power Requirements:
  • 5 VDC plus or minus 5 percent - 100 mV ripple p-p
  • 12 VDC plus or minus 5 percent - 200 mV ripple p-p
Cache Buffer
2 MB (minimum)
Start-up Time (multi-session)
less than 30 seconds typical
Stop Time
less than 4 seconds
Power DC Current
5 VDC - less than 1A typical, less than 1600 mA maximum
12 VDC - less than 600 mA typical, less than 1.4A maximum
Total Drive Power (Standby mode) - less than 2.5 watt
Power Source
Audio Output Level
0.7 Vrms (typical)
Configuration Jumper Block
Master, slave, and cable select modes
Data Interface Connector
50-pin, IDE interface
Maximum Wet Bulb Temperature (operating): 29 degrees C (84 degrees F)
Certifications, Approvals
ACA AS/NZS 3548, ANSI C63.4-1992, CB Test Certificate for IEC 950, CE Mark, CFR 47 part 15, CNS 13438, CSA C22.2 No. 60950, DHHS/FDA - 1040, EN60825, EN55022:1998, EN55024, EN60 950:2000, ICES-003 class B, IEC 61000 4-2 - 4-11, Nordic EN60 950, TUV or VDE EN60 950, UL 60950, C.I.S.P.R. Publication 22 Class B, BSMI, Microsoft® P2001, Microsoft Logo for Windows® 98, 2000 and XP
16X/40X DVD-ROM Drive
Height
5.25 inch, half-height
Interface Type
ATAPI
149.5 x 43.5 mm (5.88 x 1.71 inches)
Disc Diameter
12 cm, 6 cm
Disc Thickness
1.2 mm
Track Pitch
15 mm
Disc formats
DVD-ROM (single and dual layer); DVD-video; DVD-R version 1.0 and 2.0; DVD-RW version 1.0 and 1.1; DVD-R multi-border; DVD+RW; DVD+R, DVD+R DL ; CD-ROM Mode 1 and 2; CD-DA; CD-ROM XA Mode 2, Form 1 and 2; CD-extra; CD-text; CD-I Mode 2, Form 1 and 2; CD-I ready; video CD, CD-bridge; PhotoCD (single and multi-session); CD-R; CD-RW
Disc Capacity
DVD-ROM
4.7 GB (DVD-5), 8.54 GB (DVD-9), 9.4 GB (DVD-10), 3.95 GB (DVD-R version 1.0), 4.7 GB (DVD-R version 2.0), 4.7 GB (DVD-RW version 1.0 and 1.1), 4.7 GB (DVD+RW), 4.7G (DVD+R), 8.5 GB (DVD+R DL)
CD-ROM
540 MB (Mode 1, 12 cm), 640 MB (Mode 2, 12 cm), 700 MB (80 minimum CD-R and CD-RW), 180 MB (8 cm)
Block Size (bytes)
DVD-ROM - 2048; CD-ROM Mode 0 - 2352; CD-ROM Mode 1 - 2352, 2340, 2336, 2048; CD-ROM Mode 2 - 2352, 2340, 2336, 2048
Access Times (typical reads, including settling)
DVD-ROM Single Layer
120 ms (typically)
CD-ROM Mode 1
90 ms (typically)
Full Stroke DVD
240 ms (seek) (typically)
Full Stroke CD
160 ms (seek) (typically)
Maximum Data
CD-ROM Read: 7200 KB/s (up to 48X)
DVD-ROM Read: 21,600 KB/s (16X) Max
Data Transfer Modes
PIO Mode 4 (16.6 MB/s); Multi-word DMA mode 2 (16.6 MB/s); UltraDMA Mode 3 (44.4 MB/s)
Power
DC Current
5 VDC - less than 800 mA typical, less than 1000 mA maximum
12 VDC - less than 870 mA typical
Audio Output Level
0.7 Vrms (typical)
40-pin, shrouded and keyed, flat ribbon
Relative Humidity (operating): 10 percent to 65 percent
Maximum Wet Bulb Temperature (operating): 30 degrees C (86 degrees F)
MMC II support, multi-read certification, Microsoft WHQL certification, ACA AS/NZS 3548 class B, CNS 13438, C.I.S.P.R. Pub 22, TUV or VDE EN60950, EN 55022, EN55024, SEMKO, NEMKO, DEMKO, FIMKO, EN 60825-1, UL 60950, and CSA C22.2 60950-2000.
48X/32X/48X/16X Combo CD-RW/DVD ROM
Orientation
Interface Type
ATAPI IDE
1.2 kg (2.6 pounds)
Disc Diameter
12 cm, 8 cm
Disc Thickness
1.2 mm (0.05 inch)
Track Pitch
15 mm (0.6 inch)
1.2 m/s
Disc Capacity
Block Size (bytes)
Disc Type
CD-R and CD-RW
Write Methods
Capacity
Block Size
Full Stroke: 200 ms
Data Transfer Modes
Power
Cache Buffer
2 MB (minimum)
Stop Time
less than 4 seconds
Power DC Current
Power Source
Audio Output Level
0.7 Vrms (typical)
16X DVD+/ RW
Height
5.25 inch, half-height, tray-load
Orientation
Interface type
ATAPI/EIDE
Disc recording capacity
8.5 GB DL or 4.7 GB standard
Dimensions (W x H x D)
15.0 x 4.4 x 20.3 cm (5.9 x 1.7 x 8.0 inches)
Weight (maximum)
1.2 kg (2.6 pounds)
Write speed
  • DVD+R - up to 16X
  • DVD+RW - Up to 4X
  • DVD+R DL - up to 2.4X
  • DVD-R - up to 8X
  • DVD-RW - up to 4X
  • CD-R - up to 40X
  • CD-RW - up to 24X
Read speed
DVD+R/-R/+RW/-RW/+R DL - up to 6X
DVD-ROM - up to 16X
CD-ROM, CD-R - up to 40X
CD-RW - up to 32X
Access time (typical reads, including settling)
Random
DVD: less than 130 ms (typical), CD: less than 120 ms (typical)
Full Stroke
DVD: less than 240 ms (seek), CD: less than 200 ms (seek)
Startup Time
Single-session: less than 15 seconds (typical), Multi-session: less than 30 seconds (typical)
Stop Time
less than 4 seconds
Cache Buffer
2 MB (minimum)
Data Transfer Modes
ATA PIO mode 4 (16.7 MB/s); ATA Multi-word DMA mode 2 (16.7 MB/s); ATA UltraDMA Mode 3 (44.4 MB/s -default
Power
Source
5 VDC plus or minu 5 percent-100 mV ripple p-p
12 VDC plus or minus 5 percent -200 mV ripple p-p
DC Current
5 VDC (less than 1000 mA typical, 1600 mA maximum)
12 VDC (less than 600 mA typical, 1400 mA maximum)
Total Drive Power
less than 2.5 Watts
Audio output
Line-Out
0.7 VRMS
Signal-to-Noise Ration
74 dB
Channel Separation
65 dB
Environmental Conditions (operating - non-condensing)
Temperature
Relative humidity
Maximum wet bulb temperature
System Configuration
Intel Pentium III Processor or later with 128 MB of memory (required); 256 MB recommended 2-D or 3-D graphics cards on primary disk drive for operating system and application software; second disk drive for audio and video data
Operating System support
Regulatory approvals
MPC-3 compliant, multi-read requirements, ATA Spec X3T9.2, ATAPI Spec T13.1153D, ANSI C63.4-1992, UL 1950, ACA AS/NZS 3548, CB Bulletin No. 96A, CSA C22.2 No. 950-1995, CFR 47 C.I.S.P.R. Pub 22 Class B, DHHS/FDA, EMKO-TSE 07/94, TUV EN60950, EN60825-1, MIC, BSMI-CNS 13438, CE, Microsoft PC2001 certification, Microsoft Logo for Windows XP and 2000
Option kit contents
16X DVD+/-RW LightScribe drive, LightScribe software, InterVideo WinDVD, InterVideo WinDVD Creator, Roxio Easy Media Creator 7, Dantz Retrospect Express Backup Software, installation guide, and DVD+R media
Audio Specifications
Integrated Realtek ALC653 Audio
Feature
Specification
Type
Integrated
AC ‘97 Stereo Codec
Yes
Sampling
Supports 48 KHz
Power Support
Digital: 3.3 V
Analog: 5 V
Other
Meets performance requirements for audio on PC99/2001 systems High quality differential CD input
External Speakers need to be powered externally.
Communication Specifications
Integrated Broadcom NetXtreme Gigabit Ethernet
Connector
RJ-45
Controller
Broadcom 5751 PCI Express LAN Controller
Memory
Integrated 96Kb frame buffer memory
Data rates supported
10/100/1000 Mbps
Compliance
IEEE 802.1P, 802.1 Q, 802.2, 802.3, 802.3AB and 802.3v compliant 802.3x flow control
Bus architecture
PCI-E
Data path width
Single channel, PCI-E
Data transfer mode
Bus master DMA
Hardware certifications
FC, B, CE, TUV - cTUVus Mark Canada and United States, TUV-GS Mark for European Union
Power requirement
3.1 watts at +3.3V AUX supply with 5V tolerance
Boot ROM support
Yes
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Environmental
Operating temperature: 0 degree to 55 degree C (32 degree to 131 degree F)
Operating humidity: 55 degree C (85 percent at 131 degrees F)
Operating system driver support
MS Windows NT 4.0
MS Windows 98
MS Windows 2000
MS Windows XP
Management capabilities
ACPI, WOL and DMI 2.0, PXE 2.0, WfM 2.0, Broadcom mgmt utility
Alerting
N/A
Agere 56K PCI SoftModem
Data Transmission
Technology speeds: 56,000 Kbps maximum downstream data, controllerless
56 Kbps technology refers to download speeds only and requires compatible modems at server sites. Other conditions may limit modem speed. FCC limitations allow a maximum of 53 Kbps during download transmissions
Data speeds
(Upload only) 33,600/31,200/28,800/26,400/21,600/19,200/16,800/14,400/12,000/ 9,600/7,200/4,800/2,400/1,200/300
Data standards
ITU-T V.90, ITU-T, ITU-T V.34, V.44, V.42, V.42bis21, V.32bis, Bell 212A, and Bell 103
Fax Speeds
14,400/12,000/9,600/7,200/4,800/2,400/1,200/300 b/s
Fax Mode Capabilities
ITU-T T.31 class 1 FAX, V. 17, V.29, V.27ter, and V.21 Channel 2
Error Correction and Data Compression
V.44, 42bis, V.42 and MNP2-5
Power Management
ACPI; PPMI 1.1 and wake support with PME and Vaux; meets PCI 2.3 requirements and PC 2001 requirements
Upgradeability
Driver upgradeable for future enhancements
Video
ITU-T V.80 video ready interface
Other
TIA/EIA 602 standard AT command set
Integrated DTE interface with speeds of up to 115.2 Kbps, parallel 16550a UART-compatible interface
Optional ring wakeup signal
0 degree to 70 degrees C (32 degrees to 158 degrees F)
Operating Humidity
20 percent to 90 percent, non-condensing
Operating Systems Support
Microsoft® Windows® 2000 and Microsoft Windows XP
OS Driver Support
Microsoft Windows 2000 and Microsoft Windows XP
Power
Requires a 3.3-V auxiliary power rail on PCI bus
Uses only one PCI load (i.e., one grant/request pair), one shared IRQ, one electrical load
Graphics Specifications
Integrated Graphics Media Accelerator 900
3D/2D Controller
Support is fully compliant with Microsoft standard API such as Direct Draw, GDI/GDI+ and Direct Show
VGA Controller
Integrated
Bus Type
None
RAMDAC
Integrated, 400 MHz DAC
Memory
Graphics memory is shared with system memory. Graphics memory usage can vary from 8 – 128MB depending on the amount of system memory installed and system load. 16MB is pre-allocated for graphics use at system boot time. Additional memory is allocated for graphics using Intel's Dynamic Video Memory Technology (DVMT) to balance the optimum amount of memory between graphics and other system use. With a 128MB system, graphics memory usage will be 8MB – 32MB depending on system load. With 256MB or more, graphics memory usage will be 8MB – 128MB depending on system load.
Controller Clock Speed
333 MHz
Overlay Planes
Single overlay support with 5x3 filtering
Maximum Color Depth
32 bits/pixel
Maximum Vertical Refresh Rate
85Hz at 2048 x 1536. Varies with mode and configuration. See table below
Multi-display Support
  • Dual independent display
  • Microsoft Windows XP
Operating Systems
MS Windows XP and Windows 2000
Graphics/Video API Support
Microsoft DirectX9, DirectXVA, VMR9, GDI/GDI+; OpenGL 1.4.
Resolution
Maximum Refresh Rate (Hz)
Analog Monitor
Digital Monitor
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 1024
85
60
1600 x 1200
85
60
1920 x 1080
85
60
1920 x 1200
85
60
1920 x 1440
85
60
2048 x 1536
85
60
Keyboard Specifications
HP PS/2 or USB Standard Keyboard
Physical characteristics
Keys
104, 105, 106, 107, 109 layout (depending upon country)
45.8 x 16.3 x 2.5 cm (18.0 x 6.4 x 0.98 inches)
0.9 kg (2 lb) minimum
Electrical
Operating voltage
+ 5VDC plus/minus 5 percent
Power consumption
50 mA maximum (with three LEDs ON)
ESD
CE level 4, 15 kV air discharge
EMI - RFI
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001
Functionally compliant
Mechanical
Languages
38 available
Keycaps
Low-profile design
Switch actuation
55 g nominal peak force with tactile feedback
Switch life
20 million keystrokes (using Hasco modified tester)
Switch type
Contamination - resistant switch membrane
Key-leveling mechanisms
For all double-wide and greater-length keys
Cable length
1.8 m (6 feet)
Mechanically compliant
Acoustics
43 dBA maximum sound pressure level
Environmental
10 degrees to 50 degrees C (50 degrees to 122 degrees F)
Non-operating temperature
-30 to 60 degrees C (-22 to 140 degrees F)
Operating humidity
10 percent to 90 percent (non-condensing at ambient)
Non-operating humidity
20 percent to 80 percent (non-condensing at ambient)
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
2 g peak acceleration
Non-operating vibration
4 g peak acceleration
Drop (out of box)
66 cm (26 in) on carpet, six drop sequence
Drop (in box)
107 cm (42 in) on concrete, 16 drop sequence
Operating system support
Windows XP
Approvals
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC
Ergonomic compliance
ANSI HFS 100, ISO 9241-4, and TUVGS
Mouse Specifications
2-Button Scroll Mouse (PS/2 or USB)
Scroll Wheel
8 mm
Maximum Rotation Speed
30 mm/s
Switch Type
Light force micro-switch
Switch Life
1 million operations
Mechanical Life
Minimum 200,000 revolutions
Environmental
30 degrees to 60 degrees C (-22 degrees to 140 degrees F)
Operating Humidity
10 percent to 90 percent (non condensing at ambient)
20 percent to 80 percent (non condensing at ambient)
Operating Shock
40 g, 6 surfaces
Non-operating Shock
80 g, 6 surfaces
Operating Vibration
Non-operating Vibration
Electrical
Operating Voltage
+5VDC plus/minus 10 percent
Power Consumption
15mA
System Consumption
PS/2 mini-din connector
ESD
EMI-RFI
PC98
Mechanical
Resolution
400 plus/minus - 20 percent DPI
Tracking Speed
10 in/s maximum
Acceleration
100 inches/s
Switch Actuation
85 g nominal peak force
Switch Life
1,000,000 operations (using Hasco modified tester)
Cable Length
2 m
PC98-99
Regulatory Approvals
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BCIQ, C-Tick
Link to Product Overview Information
