    Apache Log4j Update
4-Channel Serial ATA (SATA) RAID PCI Controller - Overview
Product description
The HP 4-channel SATA RAID PCI Controller is the latest generation of the ATA interface, and an optimal solution for RAID. SATA hard drives deliver blistering transfer speeds of up to 150MB/sec. HP 4-channel SATA RAID PCI Controller supports cables that are up to one meter long and substantially thinner, eliminating cable-routing problems and increasing air circulation.
Product features
Features
Descriptions
Spare part number
348870-001 - Serial-ATA 4-port RAID controller board
415944-001 - LED cable assembly - For showing SCSI drive activity
Option part number
DM294A
Dimensions (H x D)
2.375 x 5.5 in (6 x 14 cm)
RAID level
RAID 0+1 striping/mirroring; RAID 1 mirroring; RAID 0 striping
Data transfer rate
Up to 266MB/sec (66 MHz PCI); Up to 133MB/sec (33 MHz PCI)
Cache memory
64 MB (onboard)
Device support
Up to (4) Serial ATA/150 Drives
Bus type
32-bit 33/66MHz PCI bus; PCI 2.3 compliant
BIOS
Optimizes drive performance by drive type; flashable for future upgrades; supports multiple arrays; boots system from any array; BBS compliant; setup menus for custom array creation
48-bit LBA support
Recognizes drive capacities exceeding 137GB each
Data protection features
Mirrors data to second drive or drive pair for RAID 1 and RAID 0+1; offers hot spare support for instant rebuild of failed drive in 2-drive RAID 1
Advanced data features
Bus mastering offloads data I/O handling from host CPU; CRC error-checking of Serial ATA and Ultra ATA drives for data reliability during transfers; tagged command queuing and elevator seek for optimized data handling
ACPI support
S1, S3, and S4
Internal connectors
4 standard 7-pin SATA connectors
External connectors
None
System requirements
Intel PC or equivalent with available PCI slot
Operating temperature
32° to 131° F (0° to 55° C)
Power requirements
4 amps @ +5V
Operating system support
Windows 2000 Professional, Windows XP Professional and Red Hat Linux
Kit contents
Controller card, driver CD, LED cables, user documentation and warranty card.
Others
  • Optimized disk utilization
  • Monitors status of arrays, hard drives, and controller via TCP/IP
  • Synchronizes data in fault-tolerant arrays
  • Email notification for specified array events
  • S.M.A.R.T. support
Compatibility
The HP 4-channel SATA RAID PCI Controller is compatible with the HP xw4100, xw6000, xw8000, and xw8200 Workstations.
Service and support
The HP 4-channel SATA RAID PCI Controller carries either a one-year warranty or is covered by the remainder of the warranty period for the system unit in which it is installed - whichever is longer. HP offers a 7 x 24 technical support forum on the Internet.
Links to product specification information
