HP Color LaserJet 3000, 3600 and 3800 Series Printers - Print Media Specifications
Supported media types
For optimum results, HP recommends the use of HP media designed for color LaserJet printers between the weights of 75 g/m2 to 120 g/m2. For lighter weight or heavier weight paper (60 g/m2 - 74 g/m2 and 121 - 220 g/m2), paper jam rate and optimal print quality performance may be impacted. Use the correct driver and tray settings for best results. Test all paper before purchasing large volumes.
Also for optimum results, use conventional 75 g/m2 to 90 g/sm2 (20 to 24 lb) photocopy paper. Verify that the paper is of good quality and is free of cuts, nicks, tears, spots, loose particles, dust, wrinkles, curls, or bent edges.
Tray 1 media types
Type
Dimensions
Weight or thickness
Capacity1
Plain
Minimum: 76 x 127 mm (3 x 5 inches)
Maximum: 216 x 356 mm (8.5 x 14 inches)
60 to 163 g/m2 (16 to 43 lb bond)
100 sheets
Glossy paper
HP Color LaserJet 3600 and 3800: 75 to 220 g/m2 (20 to 58 lb bond)
HP Color LaserJet 3000: 75 to 120 g/m2 (20 to 32 lb bond)
60 sheets
Transparencies2
0.12 to 0.13 mm thick (4.7 to 5 mils thick)
60 sheets
Envelopes
60 to 90 g/m2 (16 to 24 lb bond)
10 envelopes
Labels
75 to 163 g/m2 (20 to 43 lb bond)
60 sheets
Cardstock
163 to 220 g/m2 (43 to 58 lb bond)
60 sheets
NOTE 1 :Capacity can vary depending on media weight and thickness and environmental conditions. Smoothness should be 100 to 250 (Sheffield). For ordering information, see Supplies and accessories.
NOTE 2 :Use only transparencies that are designed for use with HP Color LaserJet printers. This printer can detect transparencies that were not designed for use with HP Color LaserJet printers. For more information, see Print Quality sub-menu.
Tray 2 and tray 3 media types
Type
Dimensions
Weight or thickness
Tray 2 capacity1
Tray 3 capacity1
Plain
Minimum: 148 x 210 mm (5.83 x 8.27 inches)
Maximum: 215.9 x 355.6 mm (8.5 x 14 inches)
60 to 120 g/m2 (16 to 32 lb bond)
250 sheets
500 sheets
Glossy paper
106 to 120 g/m2 (28 to 32 lb bond)
100 sheets
200 sheets
Transparencies2
50 sheets
100 sheets
Labels
50 sheets
100 sheets
NOTE 1 :The printer supports a wide range of standard and custom sizes of print media. Capacity can vary depending on media weight and thickness and environmental conditions. Smoothness should be 100 to 250 (Sheffield). For ordering information, see Supplies and accessories.
NOTE 1 :Use only transparencies that are designed for use with HP Color LaserJet printers. This printer can detect transparencies that were not designed for use with HP Color LaserJet printers. For more information, see Print Quality sub-menu.
Supported media sizes
The following are the media sizes supported on HP CLJ 3000, 3600 and 3800 Series Printers.
Input tray
Letter
Legal
A4
A5
8.5 x 13
Executive (JIS)
B5 (JIS)
Custom
Statement
Envelope1
Tray 1
Tray 2, tray 3
N/A
N/A
NOTE 1 :Supported envelope sizes are #10, Monarch, C5, DL, and B5.
Automatic 2-sided printing
Two sided printing is available on the following media sizes for HP CLJ 3000, 3600 and 3800 Series Printers.
Automatic 2-sided printing1
Media size
Dimensions
Weight and thickness
Letter
216 x 279 mm (8.5 x 11 inches)
Legal
A4
210 x 297 mm (8.3 x 11.7 inches)
8.5 x 13
216 x 330 mm (8.5 x 13 inches)
NOTE 1 :Automatic 2-sided printing on weights heavier than those shown can produce unexpected results.
Automatic 2-sided (duplex) printing is available with the HP Color LaserJet 3000dn, 3000dtn, 3600dn, 3800dn, and 3800dtn printers.
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. See Using 2-sided (duplex) printing for more information.
Country: Flag Thailand
