    Windows 11 Upgrade Guide
HP Workstation xw6000 PC Product Specifications
Product description
The HP Workstation xw6000 supports high-end Intel Xeon processors designed for the toughest analytical tasks. It can also support up to eight monitors at a time. Not only that, but it has one of the smallest minitower form factors of any workstation. The HP Workstation xw6000 will help you do business with even more efficiency.
Product features
Form factor
Minitower
Processor
  • 1 or 2 Intel Xeon processors at 2.4, 2.66 2.8, or 3.06 GHz with 512 KB L2 cache
  • 3.2 GHz with 1 MB L3 cache
Front Side Bus
533 MHz
Intel E7505
Memory
Up to 8 GB of Registered ECC PC2100 DDR-266 memory (4 DIMMs in 2 pairs, dual-channel architecture)
Expansion bays
  • 3 external 5.25 inch bays
  • 2 internal 3.5 inch bays
Drive controllers
  • Integrated dual-channel Ultra320 SCSI controller and integrated Ultra ATA/100
  • Optional Ultra160 or dual-channel Ultra320 SCSI controllers
  • Optional Ultra320 single-channel RAID controller
  • Optional SATA RAID PCI controller
Hard drive(s)
  • 40, 80, 160, 250 GB Ultra ATA/100 drives (7200 rpm)
  • 36, 73 (10K or 15K rpm), 146 GB (10K rpm) Ultra320 SCSI drives
  • 80, 160*, 250 GB (7200 rpm)
    160 GB drive is not available in all region.
  • 36, 74 GB (10K rpm) SATA drives (SATA is Windows only)
Removable media
CD-ROM, DVD-ROM, CD-RW, CD-RW+DVD combo, 8X DVD+RW 400i (Linux and Windows); 128* or 256 MB USB 2.0 drive key storage
128 MB USB 2.0 drive key is not available in all region.
5 slots:
  • 1 AGP 8X Pro 50
  • 4 full-length 32-bit 33 MHz PCI
Graphics
  • Professional 2D: NVIDIA Quadro NVS 280 (dual display), NVIDIA Quadro NVS 400 (quad display)
  • Entry 3D: NVIDIA Quadro4 380 XGL, ATI FireGL T2-128
  • Midrange 3D: NVIDIA Quadro4 980 XGL*, NVIDIA Quadro FX 1100
  • High-end 3D: NVIDIA Quadro FX 3000 (256 MB)
Audio
  • AC’97/16-bit stereo full-duplex; OR
  • Optional Sound Blaster Audigy 2 ZS (requires PCI slot)
I/O ports and connectors
  • 4 USB 2.0 ports (2 rear, 2 front)
  • one 25-pin parallel port (rear)
  • two 9-pin DIN serial (rear)
  • 3 optional IEEE 1394 (1 front, 2 rear)
  • 1 RJ-45 port (rear)
  • 1 Ultra320 SCSI 168-pin connector (rear)
Communications
  • Integrated Broadcom Gigabit LAN 10/100/1000
  • Optional Gigabit failover PCI LAN controller
Power
460 watts output
Input devices
  • Easy-access PS/2 keyboard
  • 3-button mouse (optional 2-button scroll mouse)
Dimensions (h × w × d)
44.8 x 16.8 x 44.7 cm (17.7 × 6.6 × 17.6 in)
16 kg (35 lb)
Monitors
  • HP P1230 22 inch CRT
  • HP L1925 19 inch flat panel
  • HP L2035 20.1 inch flat panel
  • HP L2335 23 inch flat panel
Parts, labor, and onsite service (3-3-3 worldwide); 24 × 7 telephone support; terms and conditions may vary, certain restrictions apply
Software overview
Feature
Supported operating systems
  • Preinstalled Microsoft Windows XP Professional
  • Preinstalled Red Hat Enterprise Linux WS 3.0, optional HP Installer Kit for Linux
