    Windows 11 Upgrade Guide
HP F2105 LCD Flat Panel Monitor - Monitor Status Message: Recommended Settings: 1680x1050@60Hz
This document applies to the HP F2105 LCD Flat Panel Monitor.
The display resolution of the PC video hardware is set to something other than the native monitor resolution of 1680x1050@60Hz. The monitor has to scale the image. When it does this, sharp lines become slightly blurred in order to enlarge or reduce the entire image. This message is a reminder to adjust the display resolution to its recommended setting to achieve best picture quality.
If blurriness occurs inside a software program, like a game, check that the resolution recommended for the game is also set to 1680x1050@60Hz.
Changing the display resolution to the displays native resolution
The native resolution for the f2105 monitor is 1680x1050. Use the following steps to set this display resolution from a Windows PC:
  1. Right-click on an open area of the Windows desktop and select Properties.
  2. Click the Settings tab.
  3. Move the slider bar under Screen Area until 1680x1050 resolution for the monitor is set, and click OK to make the change.
    If 1680x1050 is not an available display resolution, update your video card driver.
    For HP PCs, Go to the HP Software and Driver Download page and enter your PCs model name to find a listing of drivers and software updates.
    For other PCs, refer to the available drivers and downloads from the PC manufacturer Web site. For upgraded video cards, refer to the video card manufacturer Web sites:
